I am using the HKPilot Mega 2.7 and have gotten a lot of this sorted out with all of you help. Thanks!
One final issue I have is the OSD. It will only display the current info with a MAVLink connection between the computer and the telemetry radios. If I try to use them without the radios very limited data displays. The heading and orientation data displays but no location, speed, battery information.
If I establish a link everything works as it should. I can then unplug the telemetry and the OSD continues to work fine.
I googled and found the listing of parameters to change and have changed those. Still nothing.
