I created a FTS (Flight Termination System regarding the Enhanced Containment of EASA SORA), using a secondary flight controller with separate C2 link. in case of a termination, the sec. FC takes over control and lands the UAS. It works reliable.
In Standby mode, the sec. FC lowers the ThO to 0, as (of course) from its perspective, the copter flies/hovers without thrust.
When the sec. FC jumps in, two things happen:
a) it rises the throttle continuously, that leads to a descent (see screenshot).
Is there any possibility to set ThO to an value like ThH in Standby mode?
b) a “internal error 0x100000 I:57 flow_of_ctrl” is thrown. As far as I understand, this seems to be the land_detector.cpp (57)?
