Does this have the same functionallity as the larger boards? I like it since it has the same form-factor as the miniquad frames are made for (32x32mm boards)
Another question, do i need the power module? Isn´t the BEC in the ESC enough?
I would also like to know if i have any use of the airspeed sensor if i don´t use a OSD?
Hi Micke,
I have one of those MiniAPM boards, you can use the BEC from an ESC, you will need to solder a jumper on the board, personally i prefer to use the power module so i can get battery levels with the telemetry.
So far mine behaves exactly like the APM2.6, no problem with mission planning etc, note that it does need external compass, there is NO compass on the board itself, i use a NEO-6M GPS and have it on a 250mm Quad, the most usefull feature being RTH.
