I have a Matek MiniTe board with external current sensor from HGLRC.
The curr pin from the sensor is connected to the curr pin in the Matek’s plug, but I can’t get current readings working. They stay at constant, random value after powering up the board. Is there anything I need to change in AP configuration to make it work?
Yes, sorry, it’s working now. Actually not sure why, maybe power cycling the board helped, I get 0.6A on idle and 2A full throttle without props so the meter is working, now I need to adjust scale, but this is the easy part.
