Mini drak roll too sensitive in manual mode
hi,
in manual mode, the roll is too sensitive. the pitch is ok .
i’m unable to change anything in the transmitter because it’s a herelink system.
i tried to change the paramters : MIXING_GAIN : the minimum is 0.5 .
MIXING_OFFSET : the problem is that when i lower the roll , the pitch
increase…
there must be a solution but i’m unable to find it !
Thanks.
Pascal
reduce the range of the servo outputs
hi,
thanks for the answer.
i tried, it’s not good because it remains too sensitive : on the herelink system the sticks are quite small, i would like to get something more gradual .
