Mini BiCopter (3D printed frame)
Wow! Great blog post and very clean presentation!! I like that build tutorial very nice!
Thank you. So far I was sharing my experience about this crafts only in my local japanese community of mini drone makers But since the last prototypes were flying on ArduPilot I decided that it might be posted here as well. One guy build this using my tips
I think it was so far the smallest bicopter drone
ever
good job!
What are the advantages of a bicopter configuration for the time of flight? Are there any projects already done for small (3 ") bicopters with ardupilot?
Thanks
The reason for this project was just to explore the configuration and to be able to test safely indoors even in a small room. The advantages are mainly the size/ portability and depending on is the design constrain it might be more efficient. Control by motor pitch has a lot of flaws but its relatively simple to execute. I have designed an industrial grade 18 inch frame with rigid motor gimbals but so far wasn’t able to make it fly with good enough performance when testing on betaflight (it flies but sometimes becomes unstable and hard to control). I will soon switch to arducopter and try to tune it. If success then will share it here.
@Piotr it looked like you’d duplicated this post, so I rejected the other one (my assumption is you were confused when this didn’t immediately publish - we manually review the “blog” category because it is cross-fed elsewhere).
I missclicked while still editing
No problem. Cool copters by the way!
