I’m trying to use Microhard n920- 900 MHz Spread Spectrum Wireless Modem with Pixhawk Cube. It shows TTL interface in its technical specification but use rs232 cable. I made custom cable for telemetry 1 but it didn’t work. Need your suggestion?Following are technical specification of modem.
Frequency 902-928 MHz
Spreading Method Frequency Hopping / DTS
Band Segments Selectable via Freq Restriction
Forward Error Detection Hamming
BCH
Golay
Reed-Solomon
Error Detection 32 bits of CRC, ARQ
Encryption Optional (see –AES option)
Range 60+ miles (100+ km)
Sensitivity n920T
n920F
-100 dBm @ 10-4
-108 dBm @ 10-6
Output Power 100mW - 1W (20-30dBm)
Serial Interface :TTL
Serial Baud Rate - Up to 230.4 kbps asynchronous
- Up to 3.2 Mbps synchronous
Link Rate Up to 1.3824 Mbps
(higher rates available, contact Microhard for
details)
Operating Modes Point-to-Point, Point-to-Multipoint, Store &
Forward Repeater, Peer-to-Peer
Signals Interface RxD1, TxD1, RTS, CTS DCD, DSR, DTR,
RxD2, TxD2, RSSI LEDs, Tx/Rx LEDs, Reset,
Config, Wake-up, RSmode
