Hi guys,
I have several flights with a MFE Striver - Plane 4.4.0-beta 2, and around 10 flights was flying perfectly.
Today, I was doing some test flights but the plane simply didn’t keep the speed, and all the time transitioning between airplane and quadmode.
Looking the logs - generating the plane/criuse graph I see the CTUN.Tho is not good - comparing with the normal flight.
I’m my analisys I can see there is something wrong with the demanding throttle, once on the “Bad flight” the throttle is been cutoff from the flight controller.
I put a log of a good and a bad flight here:
https://drive.google.com/drive/folders/1fZBbpjydkl2N4QKJm6RtbKzRkwJZhm2I?usp=sharing
Any help I will appreciate.
Best regards
