I am using the methodic configurator and I am up to test flights. Given the difficulty of physically accessing the cube orange USB port on my drone and the number of test flights I am hoping to do I would like to have the configurator work via telemetry.
Mission planner connects reliably via UDP and TCP using a RFDesign TXMOD unit with zero issues (Yappu on the TX16S has problems with this setup, but mission planner works well).
When I try to connect via the configurator using the same TXMOD IP and port (i.e. tcp:192.168.4.1:23 ) it fails with “No MAVLink heartbeat received, connection failed”. I have made sure that mission planner is closed and I have also tried running configurator as the first application on boot (before mission planner has ever been started) just in case there is some conflict.
What I have noticed is that once I’ve tried connnecting with the configurator, mission planner won’t connect until I close the mission planner, so it does appear to be doing something…
The ArduPilot Methodic Configurator uses pymavlink to establish connection to the vehicle.
Either I’m using the pymavlink API incorrectly or this is a pymavlink bug.
I can succesffully connect with both UDP and TCP with mission planner and neither works with the configurator. I will file a bug report once I’ve triple checked everything!
As said above, I have a Python installation on Windows based on chocolatey. So I first installed necessary modules so that: mavproxy.py --master=udp:0.0.0.0:14592
succeeds, and after that: ardupilot_methodic_configurator --device udp:0.0.0.0:14592
connected beautifully, loaded parameters, etc.
In may case: pymavlink mavproxy prompt_toolkit wxPython matplotlib
