Hi there,
I have a metal detector on a drone with pixhawk. the metal detector produces a 5v signal when a metal is detected, I want to receive a signal in python on ground station using pymavlink.
what are the best ways to get around this problem.
as per my research:
- i can use the ADC port
- I can use an onbaord computer like raspberry and do all the processing on board instead of ground.
if option 1 is the optimum solution what is the best way to do it.
I do not have a raspberry, so i cannot opt from option 2.
