Menu white font on white background in dark theme
I want to report the issue I described at the title.
Using Windows 10.
The menu has black background only when I launch APM Planner in Windows XP compatibility mode.
APM Planner is not compatible with WinXP. You should run it normally as its compatible with Win7 upwards
I tried to say there is white text on white background on Win 10 and its ok only if I try it to launch with XP compatibility mode.
Ok, thanks. :geek:
Can you try a newer build from here firmware.diydrones.com/Tools/APMPlanner/beta/ it’s 2.0.19-rc3
(or you can enable beta release in APM Planner 2.0 Config view and then select check for updates to trigger the download)
Thanks
Installed that new beta but menu background is still white.
Ok we might need to update to a newer version of the Qt framework for Windows 10
Hi, I just tried RC4 and the issue is still here.
It would be nice if you solve it because it looks “buggy” for W10 users.
Thanks!
I need to update the Windows build to use a newer verson of Qt. It’s on the list, if you can build it from sourc with Qt5.5.1 and test on Windows 10 that would be great as I don’t have a Win10 machine.
