I integrated MB1242 sensor with Pixhawk.
Changed the RNGFND_MAX_CM = 700 and RNGFND_TYPE = 2.
The sonar range readings are now showing between 0.1 to 1.9 even i placed about 60cm.
Can anyone suggest any troubleshooting methods?
hi, me I’ve the same issue but my sensor its not working, did you connect it on i2c or serial?
I connected on I2C.
which thing you are using, Fixed-wing or Multi?
and which firmware version u r using?
few times, i got values around 7cm. but again it’s with the same old problem.
any troubleshooting suggested?
Me im having a quad, maybe you must isolate the sensor coz the interference
