I have integrated a Sonar Range finder on my plane for precision landings. All the parameters are set per the book and I do see voltage read in the Flight Data Status tab.
However, when I raise the plane high low, I don’t see any change in the voltage read. This cannot be a normal behavior because the sonar is a analog device and there should be some drastic change one would expect from the voltage readout.
No, there are 3x adc pins on the pixhawk, 2x are rated for 3.3v max and one has a 2:1 voltage divider on it so it can handle up to 6.6v letting it work with 5v devices so if the signal voltage from the sensor is exceeding 3.3v then you need to run it on pin 15.
If the voltage is becoming unstable then you might have a faulty sensor.
