I’m trying to run MAVSDK examples from https://github.com/mavlink/MAVSDK on my linux ubuntu machine.
Building and running any example doesn’t seem to connect to the hardware or SITL.
Here is the output of running the example “fly_mission”:
$ ./fly_mission serial:///dev/ttyACM0:115200
[03:12:55|Info ] MAVSDK version: 0.23.0 (mavsdk_impl.cpp:25)
Waiting to discover system…
[03:12:55|Debug] New: System ID: 1 Comp ID: 1 (mavsdk_impl.cpp:401)
[03:12:55|Debug] Component Autopilot (1) added. (system_impl.cpp:386)
[03:12:55|Debug] Discovered 1 component(s) (UUID: 1) (system_impl.cpp:556)
Discovered system with UUID: 1
Waiting for system to be ready
[03:12:56|Error] Error: UUID changed (system_impl.cpp:241)
[03:12:56|Warn ] command unsupported (511). (mavlink_commands.cpp:163)
[03:12:56|Error] Error: get param busy timeout: CAL_GYRO0_ID (mavlink_parameters.cpp:456)
[03:12:56|Error] Error: Param for gyro cal failed. (telemetry_impl.cpp:913)
[03:12:57|Error] Error: get param busy timeout: CAL_ACC0_ID (mavlink_parameters.cpp:456)
[03:12:57|Error] Error: Param for accel cal failed. (telemetry_impl.cpp:924)
[03:12:57|Error] Error: get param busy timeout: CAL_MAG0_ID (mavlink_parameters.cpp:456)
[03:12:57|Error] Error: Param for mag cal failed. (telemetry_impl.cpp:935)
[03:12:58|Error] Error: get param busy timeout: SYS_HITL (mavlink_parameters.cpp:456)
[03:12:58|Error] Error: Param to determine hitl failed. (telemetry_impl.cpp:959)
Getting “[Errno 111] Connection refused sleeping” when running with SITL.
