Hi guys, this is a duplicate question I have asked on rosanwer. But I figure more people here might know how to address my problem.
Hi, have recently been trying to control a rover equipped with a Pixhawk2 in an indoor environment.
For this purpose, I have followed the steps outlined in the mavros_offboard tutorial. I also had to change a few parameters on the PX4 firmware to allow the rover to arm without a GPS lock etc… I guess this should be the same for the ardurover flight stack.
After running a script similar to the tutorial one, I was able to switch to offboard mode (guided for ardurover), see below the echo of topic /mavros/state
header:
seq: 3105
stamp:
secs: 1503352094
nsecs: 242159569
frame_id: ''
connected: True
armed: True
guided: True
mode: OFFBOARD
system_status: 4
However, the mavros node interfacing with the rover is printing the following output:
[ WARN] [1503352273.909538514]: GP: No GPS fix
[ INFO] [1503352280.350340503]: HP: requesting home position
I have tried to set this position with no success.
If any of you have managed to run a px4/apm robot in an offboard mode with no GPS I would be grateful for information on:
Telling mavros/pixhawk not to expect a GPS fix
Getting the tf topic to publish something (I guess this is related to 1.)
Thanks for any help.
