I’m trying to set up MAVProxy on a RasPi (wifi bridge style) so that I can both access it via wifi, and do some local stuff with DroneKit.
I tried:
mavproxy.py --master=/dev/ttyACM0 --out=udpin:0.0.0.0:14550
then:
mavproxy.py --master=127.0.0.1:14550
on the RasPi itself, but mavproxy apparently doesn’t support UDPCI connections, but the PC UDPCI connection worked.
I tried
mavproxy.py --master=/dev/ttyACM0 --out=udpin:0.0.0.0:14550 --out=udp:127.0.0.1:14550
and the local connection worked, but the UDPCI from my PC didn’t.
Then I tried
mavproxy.py --master=/dev/ttyACM0 --out=udp:127.0.0.1:14550
in one shell, and
mavproxy.py --master=127.0.0.1:14550 --out=udpin:0.0.0.0:14560
in a second shell. As soon as the second one connected, the first one dropped out - it seems two links can’t draw from the one UDP stream.
If this is the case, how do you share a telemetry stream to multiple GCS / users / applications?
