I am trying to use MavProxy with 2 links. Link 1 is a wired connect but will later become a LOS radio. The other link is a BLOS satellite communicate. I have had the 2 links working when using 2 wired connections (adjusted baud rates to match radio speed) before, but I can’t seem to get the BLOS to work.
When I cut the connection to link 1 and only leave the BLOS communicating I can see the updates on the map of the drone position every 5 seconds (using High Latency Mode). If I try to send a command like an arm/disarm or a mode change it does not go out. I am unsure the reason causing this. Not sure if it is a bug with the ardupilot firmware (V4.6 Dev) or mavproxy. Or is my connection too poor to handle commands to the ardupilot.
Any advice/help/insight would be appreciated, thank you
