And then I am trying to run mavproxy to check if everything is okay:
rpi: $ mavproxy.py --master=/dev/serial0 --baudrate 921600
WARNING: You should uninstall ModemManager as it conflicts with APM and Pixhawk
Connect /dev/serial0 source_system=255
Log Directory:
Telemetry log: mav.tlog
Waiting for heartbeat from /dev/serial0
MAV> link 1 down
Could you please give me any pointers what could be wrong?
Could an issue be somehow connected with that I am powering FC from raspberry pi USB port?
How many Mavlink could be used at the same time? I mean that if I am using RPi’s USB port which also using Mavlink ( IIUC ) to communicate with Mission planner, could it be used another one Mavlink at the same time?
Thanks, If you /dev/ttyAMA0 everything seems to be working:
mavproxy.py --master=/dev/ttyAMA0 --baudrate 921600
Connect /dev/ttyAMA0 source_system=255
Log Directory:
Waiting for heartbeat from /dev/ttyAMA0
MAV> Detected vehicle 1:1 on link 0
online system 1
STABILIZE> Mode STABILIZE
AP: ArduCopter V4.5.4 (fd1bcc61)
AP: ChibiOS: 6a85082c
AP: speedybeef4v3 0024001B 32334717 37333831
AP: RCOut: DS600:1-4 PWM:5-7 PWM:9
AP: Frame: QUAD/X
Received 1102 parameters (ftp)
Saved 1102 parameters to mav.parm
One more question I have and probably you can help me with it. If I want to use Mavlink in halfduplex mode would it be enough just set SERIAL6_OPTION=‘halfduplex’ ( I don’t remember the number )?
And from wiring point of view how it should be connected: FC’s RX to RPI’s TX? Or it doesn’t matter?
