HI, I am trying to use Mavproxy to split telemetry stream between Missionplanner (TCP) and Antenna tracker (serial). For the moment I am testing it on Windows and I get following error:
Command:
c:\Program Files (x86)\MAVProxy\mavproxy.exe" --map --console --load-module=graph --master=tcp:192.168.4.1:5760 --out=tcpin:127.0.0.1:14550 --out=COM2,115200
Error:
Connect tcp:192.168.4.1:5760 source_system=255
Loaded module graph
Loaded module console
Loaded module map
Running script (C:\Users\kolin\AppData\Local\.mavproxy\mavinit.scr)
Loaded module help
Log Directory:
Telemetry log: mav.tlog
Waiting for heartbeat from tcp:192.168.4.1:5760
Detected vehicle 1:1 on link 0
Exception in thread main_loop:
Traceback (most recent call last):
File "threading.py", line 932, in _bootstrap_inner
File "threading.py", line 870, in run
File "mavproxy.py", line 1107, in main_loop
TypeError: argument must be an int, or have a fileno() method.
MANUAL>
I have two outputs defined. One as a TCP socket which is working and second is a serial which is not.
I am not able to test this on linux at the moment. Should there be a problem with such user case or is this a bug of Windows version?
