How can I connect MP (on windows10) to MavProxy (running on RPI3) on TCP?. Mavproxy is connected to Pixhawk on GPIO/tty of RPI3. I am making a very simple network to understand the basic concept. Both Winsows10 and RPI3 are conencted “directly” via ethernet cable and have following IPs , belong to same network.
MP is able to connect sucesfully to Mavproxy via following command. Question: What modification , in following command, require MP to connect on TCP?. is it possible to forward / stream the mavlink messages to MP on TCP or it require UDP messages wrapped in TCP?.
pi@raspberrypi:~ $
pi@raspberrypi:~ $
pi@raspberrypi:~ $ sudo mavproxy.py --master=/dev/ttyS0 --baudrate 57600 --out=udpout:169.254.193.16:14550 --aircraft MyCopter
Connect /dev/ttyS0 source_system=255
no script MyCopter/mavinit.scr
Log Directory: MyCopter/logs/2017-10-22/flight25
Telemetry log: MyCopter/logs/2017-10-22/flight25/flight.tlog
MAV> Waiting for heartbeat from /dev/ttyS0
online system 1
STABILIZE> Mode STABILIZE
fence breach
Vcc 4.1
APM: APM:Copter V3.5.3 (1a85c237)
APM: PX4: 1d6bf64c NuttX: 1a99ba58
APM: Frame: QUAD
APM: PX4v3 004D0040 3335510F 35303335
APM: PreArm: RC Roll not configured
APM: PreArm: Compass not calibrated
APM: PreArm: 3D Accel calibration needed
APM: PreArm: Check Board Voltage
APM: PreArm: Throttle below Failsafe
APM: Frame: QUAD
Received 772 parameters
Saved 772 parameters to MyCopter/logs/2017-10-22/flight25/mav.parm
Thanks Rolf: It fix the issue but a minor correction … it is –out=udpin:169.254.21.164:14550 i.e. --out=udpin:IP of RPI3, connecting to MP and NOT the MP IP …then on MP, use RPI3 IP while selecting UDPCI.
Thanks for your support.
pi@raspberrypi:~ $
pi@raspberrypi:~ $
pi@raspberrypi:~ $ sudo mavproxy.py --master=/dev/ttyS0 --baudrate 57600 --out=udpin:169.254.21.164:14550 --aircraft MyCopter
Log Directory: MyCopter/logs/2017-10-24/flight3
Telemetry log: MyCopter/logs/2017-10-24/flight3/flight.tlog
fence breach
height -20
online system 1
APM: Frame: QUAD
Saved 772 parameters to MyCopter/logs/2017-10-24/flight3/mav.parm
Dear all i too need help for same. I am connecting pixhawk with mavproxy directly using telemetry module. Is it possible to connect mavproxy using telemetry and at the same time the same telemetry with missin planner ? If yes then how and if no then why ?
Choose UDP/TCP client and speed press connect, enter ip/name and port
If you click write access, it would be possible to control drone from another GCS
Mavproxy
You can either launch Mavproxy with restream from the start via start up option --out. Examples:
i tried to established the connection of pixhawk and R-pi with mission planner using TCP. when i was doing it is seamlessly connecting with mavproxy but not with the mission planner. Will you please tell me the diagnosis that i can perform to establish a connection with mission planner also.
Hi All,
I am new in this communication protocol field and therefore I want to know that How I can establish communication between BCI system and our ground control station through TCP/IP? Can you help me with this
Secondly, to send data from mavproxy to mission planner one would use
MAVProxy’s “–out” option. e.g. “–out udp:192.16.5.6:3456” (assuming you
can get missionplanner to listen on UDP port 3456 and that’s your IP
address.
BCI system take it any system which is giving classified output.
TCP(Transmission Control Protocol) is a communication protocol I want to use for establish communication between my classifier output and Ground control station i.e. mission planner.
OK… google only tells me “Brain Computer Interface” - which would be
nifty, if a little unlikely given your description
You almost certainly want to use UDP here. Think about the properties a
TCP connection has (and what properties a UDP link has), and the
properties you want in a live link to a UAV, and consider the mismatch
between the two.
I knew Google will give you that definition…that’s why I told you BCI description according to my application
I am restricted to use TCP because TCP has several advantages over UDP such as acknowledgement, no duplicates, re-transmission etc.
Anyway thanks for the suggestion about the properties I should to see.
My doubt is how to establish the communication between classifier system (BCI system) and live GCS.
