When I use mavproxy I can set mavlink message stream frequency with command MAV_CMD_SET_MESSAGE_INTERVAL and I am getting acknowledge about it. And it works just fine. But when I switch to MAVP2P tool and I use same code to set the rates the result is highly unstable. Very often I dont get any acknowledge about it and I am unable to change the frequency. I tried to set this parameter ```
–streamreq-disable
MavP2P serial interface implementation is flawed, don’t use it. Use ser2net and create a network endpoint for your serial connection, and use that with Mavp2p.
