Mavlink to FrSky S.Port Passthru Converter for LRS or PX4 Pro
Hi ninja_zx11 - Am
Thanks for the feedback on the battery current from version 2.62.8 onwards. Are you sure you don’t mean v2.67.8? I will look at that.
Yes, the ONE-WIRE protocol has 3 levels, but what is strange is one signal is apparently inverted (idle low)), and the other is not. Check that both the RX and the ESP32 signal have the same polarity.
Hi Eric,
Yes I meant 2.62.8. I went back to 2.62.8 and my batt current readings are good again. I also noticed that the readings rise slowly with a delay if i turn my motor on but moves back instantly after switching the motor off.
Regarding the signal wave form, I think signal is idling high ( at the uninverted pad of r-xsr Rx). I captured both incoming and outgoing.I am no expert but looks like both are idling high at 3.3volts and one is coming down to 0 volts and second is coming down to 1.2volts only.
Oops, I see now that both signals are idle high :flushed: It’s a little trick to see, no?
Could I ask you to please run with this debug macro activated
#defined Debug_Batteries
and publish the results. Could you please use v2.67.16 if possible.
We should then quickly see where the problem lies. APM is designated in centiAmps, and FrSky supposedly in deciAmps.
Thanks… Yeah its kind of tricky :slight_smile: Is it okay if the 2nd signal is coming down only to 1.2volts instead of 0 volts?
I will test it tonight as you mentioned. Cheers…
Hi Eric. Here is the log. You can also notice that amps are rising slowly whereas the jump was instant from 0.4A to 0.76A when I turned on my Vtx. But Amp reading decreased instantly after I turned off my Vtx.
When the Amps were .760A , my yappu script was showing 0.1A only.
Here is the full log file:
Batt Debug log.txt (92.0 KB)
18:45:30.294 -> WiFi connected!
18:45:30.294 -> mDNS responder started
18:45:30.294 -> Local IP address: 192.168.1.70
18:45:30.294 -> WiFi RSSI:-50 dBm
18:45:30.414 -> Begin UDP using STA UDP object  read port:14555  send port:14550
18:45:30.414 -> UDP for STA started, local 192.168.1.70   remote 192.168.1.255
18:45:30.494 -> Web support active on http://mavtopass.local
18:45:32.534 -> SPort detected
18:46:59.680 -> hb_count=1
18:47:00.040 -> hb_count=2
18:47:00.560 -> hb_count=3
18:47:00.560 -> Mavlink good!
18:47:00.640 -> Battery capacities requested
18:47:00.680 -> FrPort read good!
18:47:00.880 ->  FrPeriod mS=98988	Passthru out Params 0x5007:  pt_param_id=6 pt_mission_count=0
18:47:01.000 ->  FrPeriod mS=96	Passthru out Params 0x5007:  pt_param_id=4 pt_bat1_capacity=5 pt_payload=67108869  passthru payload 0x10 05>00>00>04>	....
18:47:01.000 -> Mavlink from FC #22 Param_Value: bat1 capacity=5.00
18:47:01.080 ->  FrPeriod mS=107	Passthru out Params 0x5007:  pt_param_id=4 pt_bat1_capacity=5 pt_payload=67108869  passthru payload 0x10 05>00>00>04>	....
18:47:01.120 -> Mavlink from FC #22 Param_Value: bat1 capacity=5.00
18:47:01.120 ->  FrPeriod uS=6892	Passthru out Params 0x5007:  pt_param_id=5 pt_bat2_capacity=5 pt_payload=83886085  passthru payload 0x10 05>00>00>05>	....
18:47:01.120 -> Mavlink from FC #22 Param_Value: bat2 capacity=5.00
18:47:01.120 -> Battery params successfully read
18:47:01.200 ->  FrPeriod mS=94	Passthru out Params 0x5007:  pt_param_id=5 pt_bat2_capacity=5 pt_payload=83886085  passthru payload 0x10 05>00>00>05>	....
18:47:01.200 -> Mavlink from FC #22 Param_Value: bat2 capacity=5.00
18:47:05.071 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.433  Bat amps=0.380  mAh=11.876794  Total mAh=11.877  Bat1 cell count= 3
18:47:05.111 ->  FrPeriod mS=3892	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.3 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:05.351 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 410 ap_current_consumed mAh= 0 my di/dt mAh= 12
18:47:05.391 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.432  Bat amps=0.390  mAh=0.038551  Total mAh=11.915  Bat1 cell count= 3
18:47:05.431 ->  FrPeriod mS=311	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.3 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:05.751 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.432  Bat amps=0.400  mAh=0.040779  Total mAh=11.956  Bat1 cell count= 3
18:47:05.751 ->  FrPeriod mS=337	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:05.871 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 410 ap_current_consumed mAh= 0 my di/dt mAh= 12
18:47:06.071 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.431  Bat amps=0.410  mAh=0.042134  Total mAh=11.998  Bat1 cell count= 3
18:47:06.071 ->  FrPeriod mS=332	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:06.351 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 440 ap_current_consumed mAh= 0 my di/dt mAh= 12
18:47:06.391 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.431  Bat amps=0.410  mAh=0.041373  Total mAh=12.040  Bat1 cell count= 3
18:47:06.391 ->  FrPeriod mS=326	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:06.751 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.431  Bat amps=0.410  mAh=0.040779  Total mAh=12.080  Bat1 cell count= 3
18:47:06.751 ->  FrPeriod mS=338	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:07.071 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.430  Bat amps=0.410  mAh=0.039811  Total mAh=12.120  Bat1 cell count= 3
18:47:07.071 ->  FrPeriod mS=328	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:07.312 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 410 ap_current_consumed mAh= 0 my di/dt mAh= 12
18:47:07.392 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.430  Bat amps=0.410  mAh=0.041526  Total mAh=12.162  Bat1 cell count= 3
18:47:07.392 ->  FrPeriod mS=335	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:07.752 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.430  Bat amps=0.420  mAh=0.043403  Total mAh=12.205  Bat1 cell count= 3
18:47:07.752 ->  FrPeriod mS=342	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:08.072 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.043138  Total mAh=12.248  Bat1 cell count= 3
18:47:08.112 ->  FrPeriod mS=348	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:08.352 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 420 ap_current_consumed mAh= 0 my di/dt mAh= 12
18:47:08.392 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.420  mAh=0.038834  Total mAh=12.287  Bat1 cell count= 3
18:47:08.392 ->  FrPeriod mS=306	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:08.752 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.420  mAh=0.042890  Total mAh=12.330  Bat1 cell count= 3
18:47:08.752 ->  FrPeriod mS=346	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:09.072 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.420  mAh=0.042007  Total mAh=12.372  Bat1 cell count= 3
18:47:09.072 ->  FrPeriod mS=331	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:09.352 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 410 ap_current_consumed mAh= 0 my di/dt mAh= 12
18:47:09.392 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.420  mAh=0.042388  Total mAh=12.414  Bat1 cell count= 3
18:47:09.432 ->  FrPeriod mS=334	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:09.712 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.420  mAh=0.039171  Total mAh=12.454  Bat1 cell count= 3
18:47:09.712 ->  FrPeriod mS=317	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:10.042 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.420  mAh=0.042394  Total mAh=12.496  Bat1 cell count= 3
18:47:10.092 ->  FrPeriod mS=341	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:10.332 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 420 ap_current_consumed mAh= 0 my di/dt mAh= 12
18:47:10.412 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.420  mAh=0.041774  Total mAh=12.538  Bat1 cell count= 3
18:47:10.412 ->  FrPeriod mS=337	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:10.762 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.420  mAh=0.039171  Total mAh=12.577  Bat1 cell count= 3
18:47:10.762 ->  FrPeriod mS=316	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:11.082 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.420  mAh=0.046068  Total mAh=12.623  Bat1 cell count= 3
18:47:11.082 ->  FrPeriod mS=363	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:11.363 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 420 ap_current_consumed mAh= 0 my di/dt mAh= 13
18:47:11.403 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.420  mAh=0.038923  Total mAh=12.662  Bat1 cell count= 3
18:47:11.403 ->  FrPeriod mS=314	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:11.723 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.420  mAh=0.039543  Total mAh=12.701  Bat1 cell count= 3
18:47:11.773 ->  FrPeriod mS=319	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:12.063 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.420  mAh=0.043014  Total mAh=12.744  Bat1 cell count= 3
18:47:12.063 ->  FrPeriod mS=348	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:12.343 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 420 ap_current_consumed mAh= 0 my di/dt mAh= 13
18:47:12.423 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.420  mAh=0.044291  Total mAh=12.789  Bat1 cell count= 3
18:47:12.423 ->  FrPeriod mS=348	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:12.733 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.420  mAh=0.039171  Total mAh=12.828  Bat1 cell count= 3
18:47:12.733 ->  FrPeriod mS=316	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:13.063 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.420  mAh=0.042518  Total mAh=12.870  Bat1 cell count= 3
18:47:13.063 ->  FrPeriod mS=343	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:13.343 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 420 ap_current_consumed mAh= 0 my di/dt mAh= 13
18:47:13.383 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.420  mAh=0.041402  Total mAh=12.912  Bat1 cell count= 3
18:47:13.423 ->  FrPeriod mS=334	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:13.723 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.420  mAh=0.039047  Total mAh=12.951  Bat1 cell count= 3
18:47:13.763 ->  FrPeriod mS=315	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:14.083 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.420  mAh=0.044997  Total mAh=12.996  Bat1 cell count= 3
18:47:14.083 ->  FrPeriod mS=363	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:14.363 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 420 ap_current_consumed mAh= 1 my di/dt mAh= 13
18:47:14.403 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.039171  Total mAh=13.035  Bat1 cell count= 3
18:47:14.403 ->  FrPeriod mS=316	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:14.723 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.039667  Total mAh=13.075  Bat1 cell count= 3
18:47:14.723 ->  FrPeriod mS=320	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:15.043 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.043014  Total mAh=13.118  Bat1 cell count= 3
18:47:15.093 ->  FrPeriod mS=347	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:15.333 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 420 ap_current_consumed mAh= 1 my di/dt mAh= 13
18:47:15.373 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.041154  Total mAh=13.159  Bat1 cell count= 3
18:47:15.413 ->  FrPeriod mS=333	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:15.743 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.041030  Total mAh=13.200  Bat1 cell count= 3
18:47:15.743 ->  FrPeriod mS=330	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:16.063 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.042146  Total mAh=13.242  Bat1 cell count= 3
18:47:16.063 ->  FrPeriod mS=340	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:16.354 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 420 ap_current_consumed mAh= 1 my di/dt mAh= 13
18:47:16.354 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.038303  Total mAh=13.280  Bat1 cell count= 3
18:47:16.394 ->  FrPeriod mS=309	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:16.714 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.042518  Total mAh=13.323  Bat1 cell count= 3
18:47:16.714 ->  FrPeriod mS=343	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:17.364 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 420 ap_current_consumed mAh= 1 my di/dt mAh= 13
18:47:17.404 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.083920  Total mAh=13.407  Bat1 cell count= 3
18:47:17.404 ->  FrPeriod mS=677	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:17.754 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.040039  Total mAh=13.447  Bat1 cell count= 3
18:47:17.754 ->  FrPeriod mS=323	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:18.074 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.043014  Total mAh=13.490  Bat1 cell count= 3
18:47:18.074 ->  FrPeriod mS=347	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:18.315 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 420 ap_current_consumed mAh= 1 my di/dt mAh= 13
18:47:18.395 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.039295  Total mAh=13.529  Bat1 cell count= 3
18:47:18.395 ->  FrPeriod mS=317	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:18.725 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.041402  Total mAh=13.571  Bat1 cell count= 3
18:47:18.725 ->  FrPeriod mS=334	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:19.055 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.410  mAh=0.042890  Total mAh=13.613  Bat1 cell count= 3
18:47:19.055 ->  FrPeriod mS=346	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:19.345 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 420 ap_current_consumed mAh= 1 my di/dt mAh= 14
18:47:19.385 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.410  mAh=0.038238  Total mAh=13.652  Bat1 cell count= 3
18:47:19.385 ->  FrPeriod mS=316	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:19.705 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.410  mAh=0.042146  Total mAh=13.694  Bat1 cell count= 3
18:47:19.755 ->  FrPeriod mS=340	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:20.075 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.043509  Total mAh=13.737  Bat1 cell count= 3
18:47:20.075 ->  FrPeriod mS=351	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:20.355 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 420 ap_current_consumed mAh= 1 my di/dt mAh= 14
18:47:20.395 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.410  mAh=0.039667  Total mAh=13.777  Bat1 cell count= 3
18:47:20.395 ->  FrPeriod mS=320	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:20.715 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.040053  Total mAh=13.817  Bat1 cell count= 3
18:47:20.715 ->  FrPeriod mS=331	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:21.075 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.042890  Total mAh=13.860  Bat1 cell count= 3
18:47:21.075 ->  FrPeriod mS=346	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:21.315 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 420 ap_current_consumed mAh= 1 my di/dt mAh= 14
18:47:21.355 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.038799  Total mAh=13.899  Bat1 cell count= 3
18:47:21.395 ->  FrPeriod mS=313	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:21.765 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.410  mAh=0.041774  Total mAh=13.941  Bat1 cell count= 3
18:47:21.765 ->  FrPeriod mS=337	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:22.045 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.410  mAh=0.042110  Total mAh=13.983  Bat1 cell count= 3
18:47:22.085 ->  FrPeriod mS=348	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:22.335 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 420 ap_current_consumed mAh= 2 my di/dt mAh= 14
18:47:22.375 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.420  mAh=0.040103  Total mAh=14.023  Bat1 cell count= 3
18:47:22.375 ->  FrPeriod mS=316	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:22.765 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.410  mAh=0.042022  Total mAh=14.065  Bat1 cell count= 3
18:47:22.765 ->  FrPeriod mS=339	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:23.055 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.410  mAh=0.040039  Total mAh=14.105  Bat1 cell count= 3
18:47:23.055 ->  FrPeriod mS=323	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:23.336 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 420 ap_current_consumed mAh= 2 my di/dt mAh= 14
18:47:23.376 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.427  Bat amps=0.410  mAh=0.043261  Total mAh=14.148  Bat1 cell count= 3
18:47:23.416 ->  FrPeriod mS=349	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:23.766 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.410  mAh=0.041030  Total mAh=14.189  Bat1 cell count= 3
18:47:23.766 ->  FrPeriod mS=332	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:24.046 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.410  mAh=0.038238  Total mAh=14.227  Bat1 cell count= 3
18:47:24.046 ->  FrPeriod mS=315	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:24.326 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 420 ap_current_consumed mAh= 2 my di/dt mAh= 14
18:47:24.366 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.043261  Total mAh=14.271  Bat1 cell count= 3
18:47:24.406 ->  FrPeriod mS=349	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:24.766 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.040782  Total mAh=14.311  Bat1 cell count= 3
18:47:24.766 ->  FrPeriod mS=329	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:25.046 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.410  mAh=0.043385  Total mAh=14.355  Bat1 cell count= 3
18:47:25.096 ->  FrPeriod mS=350	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:25.336 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 430 ap_current_consumed mAh= 2 my di/dt mAh= 14
18:47:25.376 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.410  mAh=0.039047  Total mAh=14.394  Bat1 cell count= 3
18:47:25.376 ->  FrPeriod mS=315	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:25.736 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.410  mAh=0.041278  Total mAh=14.435  Bat1 cell count= 3
18:47:25.736 ->  FrPeriod mS=333	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:26.056 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.410  mAh=0.041154  Total mAh=14.476  Bat1 cell count= 3
18:47:26.056 ->  FrPeriod mS=333	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:26.373 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 420 ap_current_consumed mAh= 2 my di/dt mAh= 14
18:47:26.373 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.427  Bat amps=0.410  mAh=0.043138  Total mAh=14.519  Bat1 cell count= 3
18:47:26.413 ->  FrPeriod mS=347	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:26.773 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.427  Bat amps=0.410  mAh=0.040782  Total mAh=14.560  Bat1 cell count= 3
18:47:26.773 ->  FrPeriod mS=329	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:27.053 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.410  mAh=0.039171  Total mAh=14.599  Bat1 cell count= 3
18:47:27.053 ->  FrPeriod mS=316	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:27.333 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 420 ap_current_consumed mAh= 2 my di/dt mAh= 15
18:47:27.373 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.410  mAh=0.041526  Total mAh=14.641  Bat1 cell count= 3
18:47:27.373 ->  FrPeriod mS=335	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:27.723 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.430  mAh=0.048592  Total mAh=14.689  Bat1 cell count= 3
18:47:27.773 ->  FrPeriod mS=343	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:28.053 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.450  mAh=0.050761  Total mAh=14.740  Bat1 cell count= 3
18:47:28.103 ->  FrPeriod mS=351	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:28.313 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 480 ap_current_consumed mAh= 2 my di/dt mAh= 15
18:47:28.393 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.470  mAh=0.046337  Total mAh=14.787  Bat1 cell count= 3
18:47:28.393 ->  FrPeriod mS=314	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:28.713 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.470  mAh=0.048447  Total mAh=14.835  Bat1 cell count= 3
18:47:28.713 ->  FrPeriod mS=335	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:29.043 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.470  mAh=0.046750  Total mAh=14.882  Bat1 cell count= 3
18:47:29.043 ->  FrPeriod mS=330	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:29.372 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 480 ap_current_consumed mAh= 2 my di/dt mAh= 15
18:47:29.372 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.480  mAh=0.050616  Total mAh=14.932  Bat1 cell count= 3
18:47:29.412 ->  FrPeriod mS=350	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:29.692 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.480  mAh=0.042500  Total mAh=14.975  Bat1 cell count= 3
18:47:29.692 ->  FrPeriod mS=300	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:29.862 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 480 ap_current_consumed mAh= 2 my di/dt mAh= 15
18:47:30.022 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.427  Bat amps=0.480  mAh=0.048592  Total mAh=15.023  Bat1 cell count= 3
18:47:30.062 ->  FrPeriod mS=343	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:30.343 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 480 ap_current_consumed mAh= 3 my di/dt mAh= 15
18:47:30.393 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.480  mAh=0.048736  Total mAh=15.072  Bat1 cell count= 3
18:47:30.393 ->  FrPeriod mS=337	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:30.723 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.480  mAh=0.046467  Total mAh=15.119  Bat1 cell count= 3
18:47:30.723 ->  FrPeriod mS=328	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:30.853 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 480 ap_current_consumed mAh= 3 my di/dt mAh= 15
18:47:31.053 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.480  mAh=0.051425  Total mAh=15.170  Bat1 cell count= 3
18:47:31.093 ->  FrPeriod mS=363	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:31.333 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 470 ap_current_consumed mAh= 3 my di/dt mAh= 15
18:47:31.373 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.480  mAh=0.044483  Total mAh=15.215  Bat1 cell count= 3
18:47:31.373 ->  FrPeriod mS=314	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:31.693 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.480  mAh=0.045617  Total mAh=15.260  Bat1 cell count= 3
18:47:31.693 ->  FrPeriod mS=322	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:31.863 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 480 ap_current_consumed mAh= 3 my di/dt mAh= 15
18:47:32.023 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.429  Bat amps=0.470  mAh=0.047175  Total mAh=15.307  Bat1 cell count= 3
18:47:32.073 ->  FrPeriod mS=333	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:32.363 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 480 ap_current_consumed mAh= 3 my di/dt mAh= 15
18:47:32.403 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.470  mAh=0.051142  Total mAh=15.358  Bat1 cell count= 3
18:47:32.403 ->  FrPeriod mS=361	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:32.683 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.480  mAh=0.043530  Total mAh=15.402  Bat1 cell count= 3
18:47:32.723 ->  FrPeriod mS=302	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:33.043 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.428  Bat amps=0.480  mAh=0.049315  Total mAh=15.451  Bat1 cell count= 3
18:47:33.043 ->  FrPeriod mS=340	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:33.363 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 500 ap_current_consumed mAh= 3 my di/dt mAh= 15
18:47:33.363 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.427  Bat amps=0.490  mAh=0.051027  Total mAh=15.502  Bat1 cell count= 3
18:47:33.413 ->  FrPeriod mS=339	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.4 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:33.693 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.427  Bat amps=0.510  mAh=0.051295  Total mAh=15.554  Bat1 cell count= 3
18:47:33.693 ->  FrPeriod mS=316	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:34.053 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.427  Bat amps=0.510  mAh=0.056144  Total mAh=15.610  Bat1 cell count= 3
18:47:34.093 ->  FrPeriod mS=373	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:34.413 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 500 ap_current_consumed mAh= 3 my di/dt mAh= 16
18:47:34.413 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.427  Bat amps=0.510  mAh=0.055374  Total mAh=15.665  Bat1 cell count= 3
18:47:34.413 ->  FrPeriod mS=354	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:34.703 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.427  Bat amps=0.520  mAh=0.045614  Total mAh=15.711  Bat1 cell count= 3
18:47:34.703 ->  FrPeriod mS=281	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:34.913 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 520 ap_current_consumed mAh= 3 my di/dt mAh= 16
18:47:35.033 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.426  Bat amps=0.540  mAh=0.057174  Total mAh=15.768  Bat1 cell count= 3
18:47:35.033 ->  FrPeriod mS=334	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:35.364 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 540 ap_current_consumed mAh= 3 my di/dt mAh= 16
18:47:35.404 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.426  Bat amps=0.540  mAh=0.059766  Total mAh=15.828  Bat1 cell count= 3
18:47:35.404 ->  FrPeriod mS=375	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:35.684 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.426  Bat amps=0.540  mAh=0.047931  Total mAh=15.876  Bat1 cell count= 3
18:47:35.724 ->  FrPeriod mS=290	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:36.044 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.426  Bat amps=0.550  mAh=0.056861  Total mAh=15.933  Bat1 cell count= 3
18:47:36.044 ->  FrPeriod mS=338	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:36.364 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 700 ap_current_consumed mAh= 3 my di/dt mAh= 16
18:47:36.364 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.424  Bat amps=0.600  mAh=0.070243  Total mAh=16.003  Bat1 cell count= 3
18:47:36.414 ->  FrPeriod mS=340	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:36.724 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.424  Bat amps=0.590  mAh=0.055200  Total mAh=16.058  Bat1 cell count= 3
18:47:36.724 ->  FrPeriod mS=317	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:37.064 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.423  Bat amps=0.610  mAh=0.069830  Total mAh=16.128  Bat1 cell count= 3
18:47:37.064 ->  FrPeriod mS=364	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:37.384 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 640 ap_current_consumed mAh= 4 my di/dt mAh= 16
18:47:37.384 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.423  Bat amps=0.620  mAh=0.062711  Total mAh=16.191  Bat1 cell count= 3
18:47:37.384 ->  FrPeriod mS=332	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:37.714 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.423  Bat amps=0.620  mAh=0.057989  Total mAh=16.249  Bat1 cell count= 3
18:47:37.714 ->  FrPeriod mS=307	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:38.034 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.422  Bat amps=0.660  mAh=0.074596  Total mAh=16.323  Bat1 cell count= 3
18:47:38.034 ->  FrPeriod mS=337	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:38.364 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 730 ap_current_consumed mAh= 4 my di/dt mAh= 16
18:47:38.364 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.421  Bat amps=0.680  mAh=0.075623  Total mAh=16.399  Bat1 cell count= 3
18:47:38.414 ->  FrPeriod mS=351	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:38.704 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.422  Bat amps=0.670  mAh=0.059500  Total mAh=16.458  Bat1 cell count= 3
18:47:38.704 ->  FrPeriod mS=315	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:39.024 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.421  Bat amps=0.670  mAh=0.067814  Total mAh=16.526  Bat1 cell count= 3
18:47:39.024 ->  FrPeriod mS=334	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:39.364 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 660 ap_current_consumed mAh= 4 my di/dt mAh= 17
18:47:39.364 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.421  Bat amps=0.670  mAh=0.064671  Total mAh=16.591  Bat1 cell count= 3
18:47:39.364 ->  FrPeriod mS=331	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:39.714 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.422  Bat amps=0.650  mAh=0.059051  Total mAh=16.650  Bat1 cell count= 3
18:47:39.714 ->  FrPeriod mS=328	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:39.884 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 590 ap_current_consumed mAh= 4 my di/dt mAh= 17
18:47:40.044 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.422  Bat amps=0.650  mAh=0.071489  Total mAh=16.721  Bat1 cell count= 3
18:47:40.084 ->  FrPeriod mS=367	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:40.365 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 660 ap_current_consumed mAh= 4 my di/dt mAh= 17
18:47:40.415 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.421  Bat amps=0.650  mAh=0.064866  Total mAh=16.786  Bat1 cell count= 3
18:47:40.415 ->  FrPeriod mS=333	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:40.695 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.422  Bat amps=0.650  mAh=0.058438  Total mAh=16.845  Bat1 cell count= 3
18:47:40.695 ->  FrPeriod mS=301	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:41.025 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.421  Bat amps=0.670  mAh=0.071069  Total mAh=16.916  Bat1 cell count= 3
18:47:41.065 ->  FrPeriod mS=343	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:41.385 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 610 ap_current_consumed mAh= 4 my di/dt mAh= 17
18:47:41.385 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.422  Bat amps=0.650  mAh=0.062652  Total mAh=16.978  Bat1 cell count= 3
18:47:41.385 ->  FrPeriod mS=349	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:41.715 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.422  Bat amps=0.640  mAh=0.058570  Total mAh=17.037  Bat1 cell count= 3
18:47:41.765 ->  FrPeriod mS=314	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:42.015 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.421  Bat amps=0.640  mAh=0.063467  Total mAh=17.100  Bat1 cell count= 3
18:47:42.055 ->  FrPeriod mS=336	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:42.335 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 630 ap_current_consumed mAh= 4 my di/dt mAh= 17
18:47:42.375 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.421  Bat amps=0.630  mAh=0.061173  Total mAh=17.161  Bat1 cell count= 3
18:47:42.375 ->  FrPeriod mS=330	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:42.715 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.421  Bat amps=0.630  mAh=0.061731  Total mAh=17.223  Bat1 cell count= 3
18:47:42.765 ->  FrPeriod mS=331	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:43.005 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.421  Bat amps=0.630  mAh=0.060256  Total mAh=17.283  Bat1 cell count= 3
18:47:43.045 ->  FrPeriod mS=319	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:43.325 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 590 ap_current_consumed mAh= 5 my di/dt mAh= 17
18:47:43.365 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.421  Bat amps=0.620  mAh=0.060424  Total mAh=17.344  Bat1 cell count= 3
18:47:43.365 ->  FrPeriod mS=348	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:43.715 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.422  Bat amps=0.630  mAh=0.063883  Total mAh=17.408  Bat1 cell count= 3
18:47:43.765 ->  FrPeriod mS=332	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:43.885 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 640 ap_current_consumed mAh= 5 my di/dt mAh= 17
18:47:44.005 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.422  Bat amps=0.620  mAh=0.057824  Total mAh=17.466  Bat1 cell count= 3
18:47:44.005 ->  FrPeriod mS=316	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:44.366 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 630 ap_current_consumed mAh= 5 my di/dt mAh= 17
18:47:44.366 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.422  Bat amps=0.620  mAh=0.069541  Total mAh=17.535  Bat1 cell count= 3
18:47:44.416 ->  FrPeriod mS=374	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:44.716 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.422  Bat amps=0.630  mAh=0.061165  Total mAh=17.596  Bat1 cell count= 3
18:47:44.766 ->  FrPeriod mS=314	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:45.046 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.421  Bat amps=0.640  mAh=0.069830  Total mAh=17.666  Bat1 cell count= 3
18:47:45.086 ->  FrPeriod mS=364	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:45.366 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 670 ap_current_consumed mAh= 5 my di/dt mAh= 18
18:47:45.416 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.421  Bat amps=0.650  mAh=0.066837  Total mAh=17.733  Bat1 cell count= 3
18:47:45.416 ->  FrPeriod mS=338	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:45.716 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.421  Bat amps=0.640  mAh=0.056667  Total mAh=17.790  Bat1 cell count= 3
18:47:45.766 ->  FrPeriod mS=301	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:45.886 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 680 ap_current_consumed mAh= 5 my di/dt mAh= 18
18:47:46.046 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.420  Bat amps=0.660  mAh=0.069647  Total mAh=17.859  Bat1 cell count= 3
18:47:46.046 ->  FrPeriod mS=341	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:46.326 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 700 ap_current_consumed mAh= 5 my di/dt mAh= 18
18:47:46.406 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.420  Bat amps=0.670  mAh=0.071480  Total mAh=17.931  Bat1 cell count= 3
18:47:46.406 ->  FrPeriod mS=351	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:46.716 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.420  Bat amps=0.670  mAh=0.061705  Total mAh=17.992  Bat1 cell count= 3
18:47:46.766 ->  FrPeriod mS=303	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:46.886 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 690 ap_current_consumed mAh= 5 my di/dt mAh= 18
18:47:47.046 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.420  Bat amps=0.690  mAh=0.073737  Total mAh=18.066  Bat1 cell count= 3
18:47:47.046 ->  FrPeriod mS=348	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:47.366 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 730 ap_current_consumed mAh= 5 my di/dt mAh= 18
18:47:47.406 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.420  Bat amps=0.700  mAh=0.078424  Total mAh=18.145  Bat1 cell count= 3
18:47:47.406 ->  FrPeriod mS=364	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:47.756 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.420  Bat amps=0.690  mAh=0.060208  Total mAh=18.205  Bat1 cell count= 3
18:47:47.756 ->  FrPeriod mS=299	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:48.076 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.420  Bat amps=0.700  mAh=0.074599  Total mAh=18.279  Bat1 cell count= 3
18:47:48.076 ->  FrPeriod mS=356	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:48.326 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 690 ap_current_consumed mAh= 6 my di/dt mAh= 18
18:47:48.406 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.419  Bat amps=0.690  mAh=0.065981  Total mAh=18.345  Bat1 cell count= 3
18:47:48.406 ->  FrPeriod mS=324	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:48.716 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.420  Bat amps=0.680  mAh=0.060622  Total mAh=18.406  Bat1 cell count= 3
18:47:48.766 ->  FrPeriod mS=317	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:49.046 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.420  Bat amps=0.670  mAh=0.065226  Total mAh=18.471  Bat1 cell count= 3
18:47:49.046 ->  FrPeriod mS=339	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:49.337 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 680 ap_current_consumed mAh= 6 my di/dt mAh= 18
18:47:49.376 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.420  Bat amps=0.670  mAh=0.072516  Total mAh=18.544  Bat1 cell count= 3
18:47:49.417 ->  FrPeriod mS=351	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:49.737 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.420  Bat amps=0.690  mAh=0.066937  Total mAh=18.611  Bat1 cell count= 3
18:47:49.737 ->  FrPeriod mS=315	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.6 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:49.897 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 720 ap_current_consumed mAh= 6 my di/dt mAh= 19
18:47:50.057 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.419  Bat amps=0.700  mAh=0.073602  Total mAh=18.684  Bat1 cell count= 3
18:47:50.057 ->  FrPeriod mS=337	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:50.377 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 750 ap_current_consumed mAh= 6 my di/dt mAh= 19
18:47:50.416 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.419  Bat amps=0.720  mAh=0.080352  Total mAh=18.765  Bat1 cell count= 3
18:47:50.416 ->  FrPeriod mS=364	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:50.717 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.419  Bat amps=0.730  mAh=0.067723  Total mAh=18.832  Bat1 cell count= 3
18:47:50.756 ->  FrPeriod mS=297	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:51.036 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.418  Bat amps=0.730  mAh=0.072728  Total mAh=18.905  Bat1 cell count= 3
18:47:51.036 ->  FrPeriod mS=333	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:51.327 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 770 ap_current_consumed mAh= 6 my di/dt mAh= 19
18:47:51.407 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.418  Bat amps=0.740  mAh=0.079540  Total mAh=18.985  Bat1 cell count= 3
18:47:51.407 ->  FrPeriod mS=350	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:51.717 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.417  Bat amps=0.740  mAh=0.065742  Total mAh=19.050  Bat1 cell count= 3
18:47:51.717 ->  FrPeriod mS=297	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:51.847 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 760 ap_current_consumed mAh= 6 my di/dt mAh= 19
18:47:52.007 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.418  Bat amps=0.740  mAh=0.072728  Total mAh=19.123  Bat1 cell count= 3
18:47:52.047 ->  FrPeriod mS=334	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:52.327 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 770 ap_current_consumed mAh= 6 my di/dt mAh= 19
18:47:52.407 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.417  Bat amps=0.750  mAh=0.085221  Total mAh=19.208  Bat1 cell count= 3
18:47:52.407 ->  FrPeriod mS=374	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:52.717 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.417  Bat amps=0.750  mAh=0.064193  Total mAh=19.273  Bat1 cell count= 3
18:47:52.717 ->  FrPeriod mS=290	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:52.847 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 750 ap_current_consumed mAh= 6 my di/dt mAh= 19
18:47:53.007 -> Mavlink from FC #1 Sys_status:  Sensor health=55672859 Bat volts=11.417  Bat amps=0.760  mAh=0.078041  Total mAh=19.351  Bat1 cell count= 3
18:47:53.047 ->  FrPeriod mS=339	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:53.367 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 770 ap_current_consumed mAh= 7 my di/dt mAh= 19
18:47:53.407 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.417  Bat amps=0.760  mAh=0.087948  Total mAh=19.439  Bat1 cell count= 3
18:47:53.407 ->  FrPeriod mS=387	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:53.687 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.417  Bat amps=0.760  mAh=0.063927  Total mAh=19.502  Bat1 cell count= 3
18:47:53.737 ->  FrPeriod mS=286	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:54.057 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.417  Bat amps=0.760  mAh=0.078176  Total mAh=19.581  Bat1 cell count= 3
18:47:54.057 ->  FrPeriod mS=343	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:54.338 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 750 ap_current_consumed mAh= 7 my di/dt mAh= 20
18:47:54.378 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.417  Bat amps=0.750  mAh=0.077695  Total mAh=19.658  Bat1 cell count= 3
18:47:54.418 ->  FrPeriod mS=351	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:54.718 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.416  Bat amps=0.760  mAh=0.068404  Total mAh=19.727  Bat1 cell count= 3
18:47:54.718 ->  FrPeriod mS=301	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:54.848 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 770 ap_current_consumed mAh= 7 my di/dt mAh= 20
18:47:55.008 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.416  Bat amps=0.760  mAh=0.074540  Total mAh=19.801  Bat1 cell count= 3
18:47:55.048 ->  FrPeriod mS=329	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:55.328 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 750 ap_current_consumed mAh= 7 my di/dt mAh= 20
18:47:55.378 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.416  Bat amps=0.750  mAh=0.080573  Total mAh=19.882  Bat1 cell count= 3
18:47:55.378 ->  FrPeriod mS=363	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:55.718 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.416  Bat amps=0.760  mAh=0.068632  Total mAh=19.950  Bat1 cell count= 3
18:47:55.718 ->  FrPeriod mS=302	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:55.848 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 750 ap_current_consumed mAh= 7 my di/dt mAh= 20
18:47:56.008 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.416  Bat amps=0.750  mAh=0.073932  Total mAh=20.024  Bat1 cell count= 3
18:47:56.048 ->  FrPeriod mS=334	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:56.368 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 770 ap_current_consumed mAh= 7 my di/dt mAh= 20
18:47:56.418 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.416  Bat amps=0.760  mAh=0.089085  Total mAh=20.114  Bat1 cell count= 3
18:47:56.418 ->  FrPeriod mS=392	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:56.658 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.417  Bat amps=0.750  mAh=0.058880  Total mAh=20.172  Bat1 cell count= 3
18:47:56.698 ->  FrPeriod mS=266	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:56.858 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 750 ap_current_consumed mAh= 7 my di/dt mAh= 20
18:47:57.018 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.416  Bat amps=0.750  mAh=0.078138  Total mAh=20.251  Bat1 cell count= 3
18:47:57.068 ->  FrPeriod mS=353	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:57.318 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 770 ap_current_consumed mAh= 7 my di/dt mAh= 20
18:47:57.358 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.416  Bat amps=0.750  mAh=0.079085  Total mAh=20.330  Bat1 cell count= 3
18:47:57.398 ->  FrPeriod mS=348	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:57.678 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.416  Bat amps=0.750  mAh=0.065964  Total mAh=20.396  Bat1 cell count= 3
18:47:57.678 ->  FrPeriod mS=298	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:57.870 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 750 ap_current_consumed mAh= 8 my di/dt mAh= 20
18:47:58.030 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.416  Bat amps=0.760  mAh=0.079313  Total mAh=20.475  Bat1 cell count= 3
18:47:58.030 ->  FrPeriod mS=350	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:58.350 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 770 ap_current_consumed mAh= 8 my di/dt mAh= 20
18:47:58.390 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.416  Bat amps=0.760  mAh=0.081358  Total mAh=20.556  Bat1 cell count= 3
18:47:58.390 ->  FrPeriod mS=357	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:58.670 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.415  Bat amps=0.760  mAh=0.068859  Total mAh=20.625  Bat1 cell count= 3
18:47:58.710 ->  FrPeriod mS=303	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:58.870 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 770 ap_current_consumed mAh= 8 my di/dt mAh= 21
18:47:59.030 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.415  Bat amps=0.760  mAh=0.075222  Total mAh=20.700  Bat1 cell count= 3
18:47:59.030 ->  FrPeriod mS=331	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:59.350 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 770 ap_current_consumed mAh= 8 my di/dt mAh= 21
18:47:59.390 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.415  Bat amps=0.760  mAh=0.087039  Total mAh=20.787  Bat1 cell count= 3
18:47:59.430 ->  FrPeriod mS=383	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:59.670 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.415  Bat amps=0.760  mAh=0.063177  Total mAh=20.851  Bat1 cell count= 3
18:47:59.670 ->  FrPeriod mS=278	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:47:59.830 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 770 ap_current_consumed mAh= 8 my di/dt mAh= 21
18:48:00.030 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.415  Bat amps=0.760  mAh=0.080449  Total mAh=20.931  Bat1 cell count= 3
18:48:00.030 ->  FrPeriod mS=354	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:48:00.350 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 770 ap_current_consumed mAh= 8 my di/dt mAh= 21
18:48:00.390 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.416  Bat amps=0.760  mAh=0.079313  Total mAh=21.010  Bat1 cell count= 3
18:48:00.390 ->  FrPeriod mS=349	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:48:00.670 -> Mavlink from FC #1 Sys_status:  Sensor health=57770011 Bat volts=11.415  Bat amps=0.760  mAh=0.068177  Total mAh=21.078  Bat1 cell count= 3
18:48:00.710 ->  FrPeriod mS=300	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40 pt_bat1_amps=0.7 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
18:48:00.840 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 770 ap_current_consumed mAh= 8 my di/dt mAh= 21
18:48:01.000 -> Mavlink from FC #1 Sys_status:  Sensor health=57770043 Bat volts=11.416  Bat amps=0.760  mAh=0.075222  Total mAh=21.154  Bat1 cell count= 3
18:48:01.040 ->  FrPeriod mS=331	Passthru out Bat1 0x5003:  pt_bat1_volts=11.40
Ok, I found this change:
V2.62.8:
uint32_t Get_Current_Average1(uint16_t dA) { // in 10*milliamperes (1 = 10 milliampere)
Accum_mAh1(dA);
if (bat1.avg_dA < 1){
bat1.avg_dA = dA; // Initialise first time
bat1.avg_dA = (bat1.avg_dA * 0.6666) + (dA * 0.333); // moving average
return bat1.avg_dA;
versus V2.68.16
uint32_t Get_Current_Average1(uint16_t cA) { // in 100*milliamperes (1 = 100 milliampere)
Accum_mAh1(cA);
if (bat1.avg_cA < 1){
bat1.avg_cA = cA; // Initialise first time
bat1.avg_cA = (bat1.avg_cA * 0.6666F) + (cA * 0.333F); // moving average
return bat1.avg_cA;
The first one assumes Mavlink unit of measure is dA, and the later one assumes cA.
Note we use a running average to prevent the display jumping around trying to show the instantaneous value.
If you look at the Mavlink documentation for message type 1 here Messages (common) · MAVLink Developer Guide
you will see that the unit of measure published there is cA, so I assume that is why I changed it. I seem to recall someone reported an issue.
Be that as it may, if your Amps are coming out 10x too small, something is wrong somewhere, so I shall revert to the earlier code unless/until someone objects.
V 2.67.17 includes the earlier code. I would appreciate if you could test it. Remember, the current reading is averaged and rounded according the its magnitude, to fit the fit useful digits into the limited bits available. Forget about milliamps. The big amps while you are flying are the ones that count. :slight_smile:
Hi Eric. Thanks for checking it out. I just tried the V 2.67.17 but for some reason, its still the same issue. I am attaching the debug log.
07:05:10.005 -> WiFi connected!
07:05:10.005 -> mDNS responder started
07:05:10.045 -> Local IP address: 192.168.1.70
07:05:10.045 -> WiFi RSSI:-51 dBm
07:05:10.165 -> Begin UDP using STA UDP object  read port:14555  send port:14550
07:05:10.165 -> UDP for STA started, local 192.168.1.70   remote 192.168.1.255
07:05:10.205 -> Web support active on http://mavtopass.local
07:05:12.106 -> SPort detected
07:05:35.681 -> FrPort scheduler buffer full. Check FrPort Downlink to Taranis/Horus
07:05:45.243 -> hb_count=1
07:05:45.763 -> hb_count=2
07:05:46.244 -> hb_count=3
07:05:46.244 -> Mavlink good!
07:05:46.364 -> Battery capacities requested
07:05:46.364 -> FrPort read good!
07:05:46.444 -> Mavlink from FC #1 Sys_status:  Sensor health=17924107 Bat volts=0.000  Bat amps=-0.280  mAh=8965.950195  Total mAh=8965.950  Bat1 cell count= 0
07:05:46.484 ->  FrPeriod mS=46357	Passthru out Bat1 0x5003:  pt_bat1_volts=0.00 pt_bat1_amps=6553.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:46.564 ->  FrPeriod mS=106	Passthru out Params 0x5007:  pt_param_id=4 pt_bat1_capacity=5 pt_payload=67108869  passthru payload 0x10 05>00>00>04>	....
07:05:46.564 -> Mavlink from FC #22 Param_Value: bat1 capacity=5.00
07:05:46.604 ->  FrPeriod mS=20	Passthru out Params 0x5007:  pt_param_id=5 pt_bat2_capacity=5 pt_payload=83886085  passthru payload 0x10 05>00>00>05>	....
07:05:46.604 -> Mavlink from FC #22 Param_Value: bat2 capacity=5.00
07:05:46.604 -> Battery params successfully read
07:05:46.764 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.351  Bat amps=-218.500  mAh=0.052063  Total mAh=8966.002  Bat1 cell count= 3
07:05:46.814 ->  FrPeriod mS=189	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=6335.1 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:46.934 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 560 ap_current_consumed mAh= 0 my di/dt mAh= 8966
07:05:47.094 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.351  Bat amps=291.390  mAh=0.053231  Total mAh=8966.056  Bat1 cell count= 3
07:05:47.144 ->  FrPeriod mS=334	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=291.3 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:47.354 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 0 my di/dt mAh= 8966
07:05:47.434 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.351  Bat amps=194.420  mAh=0.051295  Total mAh=8966.107  Bat1 cell count= 3
07:05:47.434 ->  FrPeriod mS=316	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=194.4 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:47.754 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.351  Bat amps=129.790  mAh=0.057517  Total mAh=8966.165  Bat1 cell count= 3
07:05:47.794 ->  FrPeriod mS=347	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=129.7 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:48.074 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.351  Bat amps=86.690  mAh=0.050363  Total mAh=8966.216  Bat1 cell count= 3
07:05:48.114 ->  FrPeriod mS=316	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=86.6 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:48.364 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 0 my di/dt mAh= 8966
07:05:48.444 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.351  Bat amps=57.980  mAh=0.056856  Total mAh=8966.272  Bat1 cell count= 3
07:05:48.444 ->  FrPeriod mS=344	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=57.9 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:48.764 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.351  Bat amps=38.830  mAh=0.057847  Total mAh=8966.330  Bat1 cell count= 3
07:05:48.804 ->  FrPeriod mS=351	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=38.8 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:49.084 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.351  Bat amps=26.080  mAh=0.053922  Total mAh=8966.384  Bat1 cell count= 3
07:05:49.124 ->  FrPeriod mS=314	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=26.0 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:49.364 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 0 my di/dt mAh= 8966
07:05:49.444 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.351  Bat amps=17.560  mAh=0.054217  Total mAh=8966.438  Bat1 cell count= 3
07:05:49.444 ->  FrPeriod mS=335	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=17.5 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:49.764 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.352  Bat amps=11.890  mAh=0.054666  Total mAh=8966.493  Bat1 cell count= 3
07:05:49.814 ->  FrPeriod mS=342	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=11.8 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:50.094 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.352  Bat amps=8.100  mAh=0.054704  Total mAh=8966.548  Bat1 cell count= 3
07:05:50.134 ->  FrPeriod mS=337	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=8.1 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:50.384 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 0 my di/dt mAh= 8967
07:05:50.424 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.352  Bat amps=5.580  mAh=0.050363  Total mAh=8966.599  Bat1 cell count= 3
07:05:50.424 ->  FrPeriod mS=316	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=5.5 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:50.904 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 0 my di/dt mAh= 8967
07:05:50.904 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.352  Bat amps=3.900  mAh=0.078566  Total mAh=8966.677  Bat1 cell count= 3
07:05:50.904 ->  FrPeriod mS=484	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=3.9 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:51.114 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.351  Bat amps=2.780  mAh=0.030919  Total mAh=8966.708  Bat1 cell count= 3
07:05:51.114 ->  FrPeriod mS=194	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=2.7 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:51.358 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 0 my di/dt mAh= 8967
07:05:51.438 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.351  Bat amps=2.030  mAh=0.056652  Total mAh=8966.765  Bat1 cell count= 3
07:05:51.478 ->  FrPeriod mS=349	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=2.0 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:51.758 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.351  Bat amps=1.540  mAh=0.051295  Total mAh=8966.816  Bat1 cell count= 3
07:05:51.808 ->  FrPeriod mS=317	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=1.5 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:52.088 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.351  Bat amps=1.200  mAh=0.052912  Total mAh=8966.869  Bat1 cell count= 3
07:05:52.128 ->  FrPeriod mS=331	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=1.2 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:52.378 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 540 ap_current_consumed mAh= 0 my di/dt mAh= 8967
07:05:52.458 -> Mavlink from FC #1 Sys_status:  Sensor health=51478555 Bat volts=11.351  Bat amps=0.990  mAh=0.057021  Total mAh=8966.926  Bat1 cell count= 3
07:05:52.458 ->  FrPeriod mS=346	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.9 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:52.778 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.351  Bat amps=0.840  mAh=0.052918  Total mAh=8966.979  Bat1 cell count= 3
07:05:52.778 ->  FrPeriod mS=326	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.8 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:53.138 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.740  mAh=0.056100  Total mAh=8967.034  Bat1 cell count= 3
07:05:53.138 ->  FrPeriod mS=351	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.7 pt_bat1_mAh=0 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:53.349 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 1 my di/dt mAh= 8967
07:05:53.469 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.670  mAh=0.056814  Total mAh=8967.091  Bat1 cell count= 3
07:05:53.469 ->  FrPeriod mS=351	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:53.789 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.353  Bat amps=0.630  mAh=0.049185  Total mAh=8967.140  Bat1 cell count= 3
07:05:53.789 ->  FrPeriod mS=302	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:54.109 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.600  mAh=0.054866  Total mAh=8967.194  Bat1 cell count= 3
07:05:54.149 ->  FrPeriod mS=338	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:54.429 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.353  Bat amps=0.580  mAh=0.051797  Total mAh=8967.246  Bat1 cell count= 3
07:05:54.479 ->  FrPeriod mS=325	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:54.769 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.560  mAh=0.052753  Total mAh=8967.299  Bat1 cell count= 3
07:05:54.769 ->  FrPeriod mS=331	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:55.089 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.351  Bat amps=0.560  mAh=0.052594  Total mAh=8967.352  Bat1 cell count= 3
07:05:55.089 ->  FrPeriod mS=324	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:55.419 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.351  Bat amps=0.550  mAh=0.055029  Total mAh=8967.406  Bat1 cell count= 3
07:05:55.469 ->  FrPeriod mS=339	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:55.759 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.351  Bat amps=0.550  mAh=0.054188  Total mAh=8967.460  Bat1 cell count= 3
07:05:55.799 ->  FrPeriod mS=340	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:56.129 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.550  mAh=0.054704  Total mAh=8967.515  Bat1 cell count= 3
07:05:56.129 ->  FrPeriod mS=338	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:56.369 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 540 ap_current_consumed mAh= 1 my di/dt mAh= 8968
07:05:56.449 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.550  mAh=0.052724  Total mAh=8967.567  Bat1 cell count= 3
07:05:56.449 ->  FrPeriod mS=319	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:56.769 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.550  mAh=0.054055  Total mAh=8967.621  Bat1 cell count= 3
07:05:56.769 ->  FrPeriod mS=332	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:57.089 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.540  mAh=0.052275  Total mAh=8967.674  Bat1 cell count= 3
07:05:57.089 ->  FrPeriod mS=328	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:57.390 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 540 ap_current_consumed mAh= 1 my di/dt mAh= 8968
07:05:57.430 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.540  mAh=0.056977  Total mAh=8967.730  Bat1 cell count= 3
07:05:57.470 ->  FrPeriod mS=351	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:57.750 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.540  mAh=0.050970  Total mAh=8967.781  Bat1 cell count= 3
07:05:57.790 ->  FrPeriod mS=315	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:58.110 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.540  mAh=0.054217  Total mAh=8967.836  Bat1 cell count= 3
07:05:58.110 ->  FrPeriod mS=333	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:58.360 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 1 my di/dt mAh= 8968
07:05:58.440 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.353  Bat amps=0.540  mAh=0.055678  Total mAh=8967.892  Bat1 cell count= 3
07:05:58.440 ->  FrPeriod mS=344	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:58.800 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.550  mAh=0.058013  Total mAh=8967.949  Bat1 cell count= 3
07:05:58.800 ->  FrPeriod mS=350	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:59.120 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.550  mAh=0.053881  Total mAh=8968.003  Bat1 cell count= 3
07:05:59.120 ->  FrPeriod mS=327	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:59.360 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 540 ap_current_consumed mAh= 1 my di/dt mAh= 8968
07:05:59.440 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.550  mAh=0.054379  Total mAh=8968.058  Bat1 cell count= 3
07:05:59.440 ->  FrPeriod mS=334	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:05:59.760 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.351  Bat amps=0.550  mAh=0.053730  Total mAh=8968.111  Bat1 cell count= 3
07:05:59.810 ->  FrPeriod mS=331	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:00.090 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.351  Bat amps=0.550  mAh=0.050970  Total mAh=8968.162  Bat1 cell count= 3
07:06:00.090 ->  FrPeriod mS=314	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=1 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:00.370 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 2 my di/dt mAh= 8968
07:06:00.410 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.351  Bat amps=0.550  mAh=0.053730  Total mAh=8968.216  Bat1 cell count= 3
07:06:00.450 ->  FrPeriod mS=331	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:00.770 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.540  mAh=0.053231  Total mAh=8968.270  Bat1 cell count= 3
07:06:00.770 ->  FrPeriod mS=335	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:01.090 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.351  Bat amps=0.540  mAh=0.054866  Total mAh=8968.324  Bat1 cell count= 3
07:06:01.090 ->  FrPeriod mS=337	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:01.390 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 2 my di/dt mAh= 8968
07:06:01.430 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.540  mAh=0.053243  Total mAh=8968.378  Bat1 cell count= 3
07:06:01.430 ->  FrPeriod mS=328	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:01.750 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.540  mAh=0.054217  Total mAh=8968.433  Bat1 cell count= 3
07:06:01.750 ->  FrPeriod mS=334	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:02.120 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.540  mAh=0.057626  Total mAh=8968.490  Bat1 cell count= 3
07:06:02.120 ->  FrPeriod mS=355	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:02.391 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 2 my di/dt mAh= 8968
07:06:02.431 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.540  mAh=0.052756  Total mAh=8968.543  Bat1 cell count= 3
07:06:02.431 ->  FrPeriod mS=325	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:02.791 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.540  mAh=0.055191  Total mAh=8968.599  Bat1 cell count= 3
07:06:02.791 ->  FrPeriod mS=340	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:03.071 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.540  mAh=0.050159  Total mAh=8968.648  Bat1 cell count= 3
07:06:03.111 ->  FrPeriod mS=309	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:03.351 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 2 my di/dt mAh= 8969
07:06:03.431 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.550  mAh=0.056525  Total mAh=8968.705  Bat1 cell count= 3
07:06:03.431 ->  FrPeriod mS=343	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:03.751 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.550  mAh=0.053568  Total mAh=8968.759  Bat1 cell count= 3
07:06:03.751 ->  FrPeriod mS=329	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:04.081 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.353  Bat amps=0.550  mAh=0.054542  Total mAh=8968.813  Bat1 cell count= 3
07:06:04.121 ->  FrPeriod mS=336	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:04.362 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 2 my di/dt mAh= 8969
07:06:04.402 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.550  mAh=0.054376  Total mAh=8968.868  Bat1 cell count= 3
07:06:04.442 ->  FrPeriod mS=329	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:04.762 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.540  mAh=0.052434  Total mAh=8968.921  Bat1 cell count= 3
07:06:04.762 ->  FrPeriod mS=329	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:04.932 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 560 ap_current_consumed mAh= 2 my di/dt mAh= 8969
07:06:05.102 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.352  Bat amps=0.540  mAh=0.057951  Total mAh=8968.979  Bat1 cell count= 3
07:06:05.102 ->  FrPeriod mS=357	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:05.362 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 2 my di/dt mAh= 8969
07:06:05.482 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.351  Bat amps=0.540  mAh=0.058762  Total mAh=8969.037  Bat1 cell count= 3
07:06:05.482 ->  FrPeriod mS=362	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:05.762 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.351  Bat amps=0.550  mAh=0.048592  Total mAh=8969.086  Bat1 cell count= 3
07:06:05.762 ->  FrPeriod mS=294	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:06.082 -> Mavlink from FC #1 Sys_status:  Sensor health=55672891 Bat volts=11.351  Bat amps=0.550  mAh=0.052594  Total mAh=8969.139  Bat1 cell count= 3
07:06:06.082 ->  FrPeriod mS=324	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=2 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:06.382 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 3 my di/dt mAh= 8969
07:06:06.422 -> Mavlink from FC #1 Sys_status:  Sensor health=57770043 Bat volts=11.352  Bat amps=0.550  mAh=0.053568  Total mAh=8969.192  Bat1 cell count= 3
07:06:06.422 ->  FrPeriod mS=330	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:06.742 -> Mavlink from FC #1 Sys_status:  Sensor health=57770043 Bat volts=11.352  Bat amps=0.550  mAh=0.054376  Total mAh=8969.247  Bat1 cell count= 3
07:06:06.742 ->  FrPeriod mS=329	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:07.102 -> Mavlink from FC #1 Sys_status:  Sensor health=57770043 Bat volts=11.351  Bat amps=0.550  mAh=0.056490  Total mAh=8969.304  Bat1 cell count= 3
07:06:07.102 ->  FrPeriod mS=349	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:07.362 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 560 ap_current_consumed mAh= 3 my di/dt mAh= 8969
07:06:07.402 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.352  Bat amps=0.550  mAh=0.051944  Total mAh=8969.355  Bat1 cell count= 3
07:06:07.442 ->  FrPeriod mS=319	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:07.762 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.352  Bat amps=0.550  mAh=0.056856  Total mAh=8969.412  Bat1 cell count= 3
07:06:07.762 ->  FrPeriod mS=344	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:07.932 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 560 ap_current_consumed mAh= 3 my di/dt mAh= 8969
07:06:08.092 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.550  mAh=0.051295  Total mAh=8969.464  Bat1 cell count= 3
07:06:08.092 ->  FrPeriod mS=316	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:08.393 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 3 my di/dt mAh= 8969
07:06:08.433 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.352  Bat amps=0.550  mAh=0.057517  Total mAh=8969.521  Bat1 cell count= 3
07:06:08.433 ->  FrPeriod mS=349	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:08.753 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.550  mAh=0.057351  Total mAh=8969.579  Bat1 cell count= 3
07:06:08.793 ->  FrPeriod mS=346	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:08.913 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 560 ap_current_consumed mAh= 3 my di/dt mAh= 8970
07:06:09.073 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.352  Bat amps=0.550  mAh=0.047972  Total mAh=8969.627  Bat1 cell count= 3
07:06:09.073 ->  FrPeriod mS=301	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:09.373 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 540 ap_current_consumed mAh= 3 my di/dt mAh= 8970
07:06:09.413 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.550  mAh=0.057351  Total mAh=8969.685  Bat1 cell count= 3
07:06:09.413 ->  FrPeriod mS=347	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:09.773 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.352  Bat amps=0.550  mAh=0.055191  Total mAh=8969.740  Bat1 cell count= 3
07:06:09.773 ->  FrPeriod mS=341	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:10.053 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.352  Bat amps=0.550  mAh=0.051567  Total mAh=8969.792  Bat1 cell count= 3
07:06:10.093 ->  FrPeriod mS=311	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:10.373 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 560 ap_current_consumed mAh= 3 my di/dt mAh= 8970
07:06:10.413 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.550  mAh=0.056490  Total mAh=8969.849  Bat1 cell count= 3
07:06:10.413 ->  FrPeriod mS=348	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:10.733 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.550  mAh=0.054707  Total mAh=8969.903  Bat1 cell count= 3
07:06:10.783 ->  FrPeriod mS=331	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:11.063 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.550  mAh=0.051295  Total mAh=8969.955  Bat1 cell count= 3
07:06:11.063 ->  FrPeriod mS=316	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:11.363 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 3 my di/dt mAh= 8970
07:06:11.443 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.550  mAh=0.061522  Total mAh=8970.017  Bat1 cell count= 3
07:06:11.443 ->  FrPeriod mS=380	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:11.763 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.350  Bat amps=0.550  mAh=0.051457  Total mAh=8970.068  Bat1 cell count= 3
07:06:11.763 ->  FrPeriod mS=316	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:12.083 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.352  Bat amps=0.550  mAh=0.051295  Total mAh=8970.120  Bat1 cell count= 3
07:06:12.083 ->  FrPeriod mS=316	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:12.384 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 3 my di/dt mAh= 8970
07:06:12.424 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.352  Bat amps=0.550  mAh=0.059996  Total mAh=8970.180  Bat1 cell count= 3
07:06:12.464 ->  FrPeriod mS=364	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:12.744 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.352  Bat amps=0.550  mAh=0.051295  Total mAh=8970.231  Bat1 cell count= 3
07:06:12.784 ->  FrPeriod mS=316	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:13.064 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.353  Bat amps=0.550  mAh=0.051133  Total mAh=8970.282  Bat1 cell count= 3
07:06:13.064 ->  FrPeriod mS=315	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=3 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:13.364 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 4 my di/dt mAh= 8970
07:06:13.404 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.352  Bat amps=0.550  mAh=0.057682  Total mAh=8970.340  Bat1 cell count= 3
07:06:13.444 ->  FrPeriod mS=348	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:13.764 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.352  Bat amps=0.550  mAh=0.055516  Total mAh=8970.396  Bat1 cell count= 3
07:06:13.764 ->  FrPeriod mS=342	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:14.054 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.550  mAh=0.050244  Total mAh=8970.445  Bat1 cell count= 3
07:06:14.094 ->  FrPeriod mS=305	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:14.374 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 4 my di/dt mAh= 8970
07:06:14.414 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.550  mAh=0.056652  Total mAh=8970.502  Bat1 cell count= 3
07:06:14.414 ->  FrPeriod mS=349	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:14.714 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.550  mAh=0.051897  Total mAh=8970.554  Bat1 cell count= 3
07:06:14.754 ->  FrPeriod mS=313	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:14.914 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 4 my di/dt mAh= 8971
07:06:15.044 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.550  mAh=0.054217  Total mAh=8970.608  Bat1 cell count= 3
07:06:15.084 ->  FrPeriod mS=335	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:15.364 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 4 my di/dt mAh= 8971
07:06:15.404 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.350  Bat amps=0.550  mAh=0.058275  Total mAh=8970.667  Bat1 cell count= 3
07:06:15.444 ->  FrPeriod mS=359	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:15.764 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.550  mAh=0.055029  Total mAh=8970.722  Bat1 cell count= 3
07:06:15.764 ->  FrPeriod mS=338	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:15.894 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 4 my di/dt mAh= 8971
07:06:16.054 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.550  mAh=0.050321  Total mAh=8970.772  Bat1 cell count= 3
07:06:16.094 ->  FrPeriod mS=311	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:16.365 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 550 ap_current_consumed mAh= 4 my di/dt mAh= 8971
07:06:16.405 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.550  mAh=0.058013  Total mAh=8970.830  Bat1 cell count= 3
07:06:16.445 ->  FrPeriod mS=350	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:16.765 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.570  mAh=0.058871  Total mAh=8970.889  Bat1 cell count= 3
07:06:16.765 ->  FrPeriod mS=327	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:17.085 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.352  Bat amps=0.580  mAh=0.058739  Total mAh=8970.947  Bat1 cell count= 3
07:06:17.085 ->  FrPeriod mS=322	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.5 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:17.355 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 620 ap_current_consumed mAh= 4 my di/dt mAh= 8971
07:06:17.475 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.600  mAh=0.073073  Total mAh=8971.021  Bat1 cell count= 3
07:06:17.475 ->  FrPeriod mS=392	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:17.755 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.600  mAh=0.054896  Total mAh=8971.075  Bat1 cell count= 3
07:06:17.795 ->  FrPeriod mS=300	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:17.915 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 620 ap_current_consumed mAh= 4 my di/dt mAh= 8971
07:06:18.075 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.600  mAh=0.054551  Total mAh=8971.130  Bat1 cell count= 3
07:06:18.075 ->  FrPeriod mS=303	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:18.355 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 620 ap_current_consumed mAh= 4 my di/dt mAh= 8971
07:06:18.395 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.600  mAh=0.062472  Total mAh=8971.192  Bat1 cell count= 3
07:06:18.435 ->  FrPeriod mS=348	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:18.715 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.610  mAh=0.058007  Total mAh=8971.250  Bat1 cell count= 3
07:06:18.755 ->  FrPeriod mS=316	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=4 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:18.915 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 610 ap_current_consumed mAh= 5 my di/dt mAh= 8971
07:06:19.075 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.610  mAh=0.061752  Total mAh=8971.312  Bat1 cell count= 3
07:06:19.075 ->  FrPeriod mS=343	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:19.375 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 620 ap_current_consumed mAh= 5 my di/dt mAh= 8971
07:06:19.415 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.610  mAh=0.065078  Total mAh=8971.377  Bat1 cell count= 3
07:06:19.415 ->  FrPeriod mS=351	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:19.775 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.610  mAh=0.061572  Total mAh=8971.438  Bat1 cell count= 3
07:06:19.775 ->  FrPeriod mS=341	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:20.055 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.610  mAh=0.054370  Total mAh=8971.493  Bat1 cell count= 3
07:06:20.095 ->  FrPeriod mS=302	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:20.355 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 600 ap_current_consumed mAh= 5 my di/dt mAh= 8971
07:06:20.435 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.610  mAh=0.064777  Total mAh=8971.558  Bat1 cell count= 3
07:06:20.435 ->  FrPeriod mS=354	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:20.715 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.351  Bat amps=0.610  mAh=0.057455  Total mAh=8971.615  Bat1 cell count= 3
07:06:20.755 ->  FrPeriod mS=310	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:21.075 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.350  Bat amps=0.620  mAh=0.065034  Total mAh=8971.681  Bat1 cell count= 3
07:06:21.075 ->  FrPeriod mS=338	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:21.386 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 660 ap_current_consumed mAh= 5 my di/dt mAh= 8972
07:06:21.426 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.348  Bat amps=0.640  mAh=0.068617  Total mAh=8971.749  Bat1 cell count= 3
07:06:21.426 ->  FrPeriod mS=348	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:21.746 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.347  Bat amps=0.650  mAh=0.069012  Total mAh=8971.818  Bat1 cell count= 3
07:06:21.796 ->  FrPeriod mS=348	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:21.916 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 670 ap_current_consumed mAh= 5 my di/dt mAh= 8972
07:06:22.076 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.346  Bat amps=0.650  mAh=0.059125  Total mAh=8971.878  Bat1 cell count= 3
07:06:22.076 ->  FrPeriod mS=300	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:22.376 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 690 ap_current_consumed mAh= 5 my di/dt mAh= 8972
07:06:22.416 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.345  Bat amps=0.670  mAh=0.074375  Total mAh=8971.952  Bat1 cell count= 3
07:06:22.416 ->  FrPeriod mS=360	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:22.736 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.344  Bat amps=0.680  mAh=0.069487  Total mAh=8972.021  Bat1 cell count= 3
07:06:22.776 ->  FrPeriod mS=326	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:23.056 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.343  Bat amps=0.680  mAh=0.066185  Total mAh=8972.088  Bat1 cell count= 3
07:06:23.096 ->  FrPeriod mS=325	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:23.386 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 690 ap_current_consumed mAh= 5 my di/dt mAh= 8972
07:06:23.466 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.343  Bat amps=0.690  mAh=0.079475  Total mAh=8972.167  Bat1 cell count= 3
07:06:23.466 ->  FrPeriod mS=375	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:23.746 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.343  Bat amps=0.700  mAh=0.067867  Total mAh=8972.234  Bat1 cell count= 3
07:06:23.786 ->  FrPeriod mS=315	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.7 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:24.066 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.710  mAh=0.065025  Total mAh=8972.300  Bat1 cell count= 3
07:06:24.066 ->  FrPeriod mS=305	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.7 pt_bat1_mAh=5 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:24.386 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 710 ap_current_consumed mAh= 6 my di/dt mAh= 8972
07:06:24.436 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.710  mAh=0.074977  Total mAh=8972.375  Bat1 cell count= 3
07:06:24.436 ->  FrPeriod mS=348	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.7 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:24.726 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.720  mAh=0.069015  Total mAh=8972.444  Bat1 cell count= 3
07:06:24.726 ->  FrPeriod mS=317	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.7 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:24.896 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 730 ap_current_consumed mAh= 6 my di/dt mAh= 8972
07:06:25.056 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.720  mAh=0.072291  Total mAh=8972.517  Bat1 cell count= 3
07:06:25.106 ->  FrPeriod mS=330	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.7 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:25.356 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 890 ap_current_consumed mAh= 6 my di/dt mAh= 8973
07:06:25.396 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.750  mAh=0.084221  Total mAh=8972.601  Bat1 cell count= 3
07:06:25.436 ->  FrPeriod mS=348	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.7 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:25.756 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.750  mAh=0.078956  Total mAh=8972.680  Bat1 cell count= 3
07:06:25.796 ->  FrPeriod mS=352	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.7 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:26.076 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.780  mAh=0.078271  Total mAh=8972.758  Bat1 cell count= 3
07:06:26.076 ->  FrPeriod mS=313	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.7 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:26.396 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 820 ap_current_consumed mAh= 6 my di/dt mAh= 8973
07:06:26.436 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.341  Bat amps=0.790  mAh=0.083194  Total mAh=8972.841  Bat1 cell count= 3
07:06:26.436 ->  FrPeriod mS=347	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.7 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:26.716 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.341  Bat amps=0.790  mAh=0.070833  Total mAh=8972.912  Bat1 cell count= 3
07:06:26.766 ->  FrPeriod mS=300	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.7 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:27.046 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.341  Bat amps=0.840  mAh=0.092107  Total mAh=8973.004  Bat1 cell count= 3
07:06:27.096 ->  FrPeriod mS=333	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.8 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:27.387 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 900 ap_current_consumed mAh= 6 my di/dt mAh= 8973
07:06:27.427 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.340  Bat amps=0.870  mAh=0.099636  Total mAh=8973.104  Bat1 cell count= 3
07:06:27.427 ->  FrPeriod mS=363	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.8 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:27.747 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.340  Bat amps=0.860  mAh=0.086800  Total mAh=8973.190  Bat1 cell count= 3
07:06:27.787 ->  FrPeriod mS=345	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.8 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:27.907 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 870 ap_current_consumed mAh= 6 my di/dt mAh= 8973
07:06:28.067 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.340  Bat amps=0.840  mAh=0.067655  Total mAh=8973.258  Bat1 cell count= 3
07:06:28.067 ->  FrPeriod mS=284	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.8 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:28.357 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 890 ap_current_consumed mAh= 6 my di/dt mAh= 8973
07:06:28.397 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.340  Bat amps=0.850  mAh=0.094235  Total mAh=8973.352  Bat1 cell count= 3
07:06:28.437 ->  FrPeriod mS=366	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.8 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:28.757 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.340  Bat amps=0.820  mAh=0.076659  Total mAh=8973.428  Bat1 cell count= 3
07:06:28.757 ->  FrPeriod mS=334	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.8 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:29.047 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.340  Bat amps=0.820  mAh=0.071480  Total mAh=8973.499  Bat1 cell count= 3
07:06:29.047 ->  FrPeriod mS=299	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.8 pt_bat1_mAh=6 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:29.387 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 810 ap_current_consumed mAh= 7 my di/dt mAh= 8973
07:06:29.467 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.340  Bat amps=0.820  mAh=0.102640  Total mAh=8973.602  Bat1 cell count= 3
07:06:29.467 ->  FrPeriod mS=418	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.8 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:29.747 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.340  Bat amps=0.810  mAh=0.071069  Total mAh=8973.673  Bat1 cell count= 3
07:06:29.787 ->  FrPeriod mS=301	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.8 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:29.907 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 840 ap_current_consumed mAh= 7 my di/dt mAh= 8974
07:06:30.067 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.340  Bat amps=0.810  mAh=0.070184  Total mAh=8973.743  Bat1 cell count= 3
07:06:30.067 ->  FrPeriod mS=290	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.8 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:30.387 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 780 ap_current_consumed mAh= 7 my di/dt mAh= 8974
07:06:30.427 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.340  Bat amps=0.820  mAh=0.089994  Total mAh=8973.833  Bat1 cell count= 3
07:06:30.427 ->  FrPeriod mS=363	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.8 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:30.747 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.340  Bat amps=0.840  mAh=0.081553  Total mAh=8973.915  Bat1 cell count= 3
07:06:30.747 ->  FrPeriod mS=314	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.8 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:31.067 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.340  Bat amps=0.830  mAh=0.075992  Total mAh=8973.991  Bat1 cell count= 3
07:06:31.067 ->  FrPeriod mS=315	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.8 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:31.398 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 820 ap_current_consumed mAh= 7 my di/dt mAh= 8974
07:06:31.398 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.340  Bat amps=0.810  mAh=0.085177  Total mAh=8974.076  Bat1 cell count= 3
07:06:31.438 ->  FrPeriod mS=369	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.8 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:31.758 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.340  Bat amps=0.810  mAh=0.083672  Total mAh=8974.160  Bat1 cell count= 3
07:06:31.798 ->  FrPeriod mS=350	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.8 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:32.038 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.339  Bat amps=0.810  mAh=0.067855  Total mAh=8974.228  Bat1 cell count= 3
07:06:32.038 ->  FrPeriod mS=277	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.8 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:32.398 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 770 ap_current_consumed mAh= 7 my di/dt mAh= 8974
07:06:32.438 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.340  Bat amps=0.800  mAh=0.087039  Total mAh=8974.314  Bat1 cell count= 3
07:06:32.438 ->  FrPeriod mS=383	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.8 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:32.718 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.341  Bat amps=0.740  mAh=0.055967  Total mAh=8974.370  Bat1 cell count= 3
07:06:32.758 ->  FrPeriod mS=302	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.7 pt_bat1_mAh=7 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:32.918 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 640 ap_current_consumed mAh= 8 my di/dt mAh= 8974
07:06:33.038 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.341  Bat amps=0.710  mAh=0.060813  Total mAh=8974.431  Bat1 cell count= 3
07:06:33.078 ->  FrPeriod mS=317	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.7 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:33.379 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 630 ap_current_consumed mAh= 8 my di/dt mAh= 8974
07:06:33.419 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.341  Bat amps=0.680  mAh=0.068378  Total mAh=8974.499  Bat1 cell count= 3
07:06:33.419 ->  FrPeriod mS=362	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:33.779 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.660  mAh=0.066937  Total mAh=8974.566  Bat1 cell count= 3
07:06:33.779 ->  FrPeriod mS=360	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:34.059 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.650  mAh=0.053267  Total mAh=8974.620  Bat1 cell count= 3
07:06:34.059 ->  FrPeriod mS=281	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:34.379 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 630 ap_current_consumed mAh= 8 my di/dt mAh= 8975
07:06:34.429 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.650  mAh=0.070981  Total mAh=8974.691  Bat1 cell count= 3
07:06:34.429 ->  FrPeriod mS=371	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:34.719 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.650  mAh=0.053833  Total mAh=8974.745  Bat1 cell count= 3
07:06:34.719 ->  FrPeriod mS=285	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:35.039 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.341  Bat amps=0.640  mAh=0.065544  Total mAh=8974.811  Bat1 cell count= 3
07:06:35.079 ->  FrPeriod mS=347	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:35.369 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 640 ap_current_consumed mAh= 8 my di/dt mAh= 8975
07:06:35.409 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.640  mAh=0.064148  Total mAh=8974.875  Bat1 cell count= 3
07:06:35.409 ->  FrPeriod mS=345	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:35.769 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.341  Bat amps=0.640  mAh=0.070456  Total mAh=8974.945  Bat1 cell count= 3
07:06:35.769 ->  FrPeriod mS=373	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:35.899 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 630 ap_current_consumed mAh= 8 my di/dt mAh= 8975
07:06:36.059 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.630  mAh=0.052133  Total mAh=8974.997  Bat1 cell count= 3
07:06:36.059 ->  FrPeriod mS=275	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:36.379 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 640 ap_current_consumed mAh= 8 my di/dt mAh= 8975
07:06:36.379 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.630  mAh=0.065264  Total mAh=8975.063  Bat1 cell count= 3
07:06:36.419 ->  FrPeriod mS=351	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:36.739 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.630  mAh=0.061359  Total mAh=8975.124  Bat1 cell count= 3
07:06:36.739 ->  FrPeriod mS=330	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:37.069 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.630  mAh=0.061964  Total mAh=8975.186  Bat1 cell count= 3
07:06:37.069 ->  FrPeriod mS=323	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:37.359 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 630 ap_current_consumed mAh= 8 my di/dt mAh= 8975
07:06:37.399 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.630  mAh=0.066111  Total mAh=8975.252  Bat1 cell count= 3
07:06:37.399 ->  FrPeriod mS=351	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:37.759 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.343  Bat amps=0.630  mAh=0.068611  Total mAh=8975.320  Bat1 cell count= 3
07:06:37.809 ->  FrPeriod mS=369	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:37.889 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 650 ap_current_consumed mAh= 8 my di/dt mAh= 8975
07:06:38.049 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.343  Bat amps=0.630  mAh=0.053833  Total mAh=8975.374  Bat1 cell count= 3
07:06:38.049 ->  FrPeriod mS=285	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:38.350 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 630 ap_current_consumed mAh= 8 my di/dt mAh= 8975
07:06:38.390 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.640  mAh=0.065801  Total mAh=8975.439  Bat1 cell count= 3
07:06:38.429 ->  FrPeriod mS=342	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:38.709 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.640  mAh=0.060822  Total mAh=8975.500  Bat1 cell count= 3
07:06:38.750 ->  FrPeriod mS=322	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=8 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:38.909 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 630 ap_current_consumed mAh= 9 my di/dt mAh= 8976
07:06:39.030 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.640  mAh=0.061767  Total mAh=8975.562  Bat1 cell count= 3
07:06:39.070 ->  FrPeriod mS=327	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=9 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:39.359 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 640 ap_current_consumed mAh= 9 my di/dt mAh= 8976
07:06:39.399 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.630  mAh=0.065264  Total mAh=8975.627  Bat1 cell count= 3
07:06:39.399 ->  FrPeriod mS=351	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=9 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:39.759 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.630  mAh=0.070644  Total mAh=8975.697  Bat1 cell count= 3
07:06:39.809 ->  FrPeriod mS=375	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=9 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:40.049 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.343  Bat amps=0.630  mAh=0.051133  Total mAh=8975.748  Bat1 cell count= 3
07:06:40.049 ->  FrPeriod mS=274	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=9 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:40.360 -> Mavlink from FC #147 Battery Status:  bat id= 0 bat current mA= 640 ap_current_consumed mAh= 9 my di/dt mAh= 8976
07:06:40.440 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.630  mAh=0.072887  Total mAh=8975.821  Bat1 cell count= 3
07:06:40.440 ->  FrPeriod mS=392	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=9 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:40.720 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.630  mAh=0.050575  Total mAh=8975.872  Bat1 cell count= 3
07:06:40.720 ->  FrPeriod mS=272	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=9 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
07:06:41.040 -> Mavlink from FC #1 Sys_status:  Sensor health=326205499 Bat volts=11.342  Bat amps=0.630  mAh=0.064789  Total mAh=8975.937  Bat1 cell count= 3
07:06:41.090 ->  FrPeriod mS=344	Passthru out Bat1 0x5003:  pt_bat1_volts=11.30 pt_bat1_amps=0.6 pt_bat1_mAh=9 pt_payload=0  passthru payload 0x10 00>00>00>00>	....
Hi Eric,
I tried flashing again but same issue. Its still showing 1/10 of the actual reading. But I did notice that values goes up and down in a more natural way. Before it was taking around 6 secs to get to the actual value. Thanks for taking time to solve this issue.
Am:
Ok fixed, I missed a line
Thanks again for the feedback. I just pushed v2.67.17 again.
Awesome…I will test it soon.
One more question please. How to download just one version from github without dowliading the complete zip file which contains every version. Thanks.
Install GitHub Desktop and clone the MavlinkToPassthru repository to PC. Then if you “Fetch Origin”, it will download only the changed files.
Hello Eric. Its fixed!! Amp reading on Yappu screen is correct now. Thanks for taking time to fix it.
Another minor thing I noticed that Amp reading on the Oled screen of Heltec is showing 1 amps instead of 0.1Amps . So its showing 10 times for some reason :slight_smile:
Done. Thanks again for the feedback.
Hi Eric,
Now the Amp reading on Heltec OLED is stuck at 0 Amps. Its not changing even plane amp goes over 1 amps.
Hey @ninja_zx11. Sorry for the long absence. I’ve been travelling and got some other stuff going on. Is this still a problem?
Hello Eric. No worries at all…
Actually yes there is still an issue with the latest.Amp reading is stuck at 0 if using latest.
I then went back to one version earlier (june 1st) and amp reading is working except the reading is one decimal place is off on June 1st firmware. Thanks.
Quick question. Was the bad amp reading on the oled display or on the transmitter screen?
@ninja_zx11 Please could you try v2.68.03 when you get a chance. I can’t test it properly where I am.
Hi Eric. Sorry forbthe delay. Will do it in few days as I just had sinus surgery few days ago.
No worries. Get better soon my friend.
