Starting stress tests in AP mode:
Starting MavToPass_v2.62.1 …
Display support activated
EEPROM initialised successfully
EEPROM settings read and adopted
Target Board is ESP32 / Variant is Heltec Wifi Kit 32
Ground Mode
Battery_mAh_Source = 3 - Define battery capacities in the LUA script
RSSI Override for testing = 70%
Mavlink Bluetooth In
Mavlink WiFi Out - WiFi mode is STA/AP
Protocol is UDP
Bluetooth master mode host RHS_CF is trying to connect to slave Crossfire 0277. This can take up to 30s
Bluetooth done
S.Port on ESP is inverted on tx pin = 14
Wi-Fi mode set to WIFI_AP
AP IP address: 192.168.4.1 SSID: CF_AP
UDP started, listening on IP 192.168.4.1, port 14555
Web support active on http://192.168.4.1
hb_count=1
hb_count=2
hb_count=3
Mavlink good!
UDP client connected, remote IP: 192.168.4.2, remote port: 14550
[QGroundControl loads the parameters from here and stops at about 90%. After that the following messages appear:]
Mavlink to FC: #20 Param_Request_Read: gcs_target_system=1 gcs_req_param_id= gcs_req_param_index=39
Mavlink to FC: #20 Param_Request_Read: gcs_target_system=1 gcs_req_param_id= gcs_req_param_index=40
Mavlink to FC: #20 Param_Request_Read: gcs_target_system=1 gcs_req_param_id= gcs_req_param_index=41
[some lines deleted]
Mavlink to FC: #20 Param_Request_Read: gcs_target_system=1 gcs_req_param_id= gcs_req_param_index=195
Mavlink to FC: #20 Param_Request_Read: gcs_target_system=1 gcs_req_param_id= gcs_req_param_index=196
Mavlink to FC: #20 Param_Request_Read: gcs_target_system=1 gcs_req_param_id= gcs_req_param_index=197
abort() was called at PC 0x401c6797 on core 1
Backtrace: 0x40092874:0x3ffd5380 0x40092aa5:0x3ffd53a0 0x401c6797:0x3ffd53c0 0x401c67de:0x3ffd53e0 0x401b8fdb:0x3ffd5400 0x401b90ce:0x3ffd5420 0x401b9085:0x3ffd5440 0x400dc8db:0x3ffd5460 0x400d82d1:0x3ffd54a0 0x400d8463:0x3ffd54f0 0x400d9471:0x3ffd5530 0x400e35c9:0x3ffd5590 0x4008ef89:0x3ffd55b0
Rebooting…
ets Jun 8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:1216
ho 0 tail 12 room 4
load:0x40078000,len:9720
ho 0 tail 12 room 4
load:0x40080400,len:6364
entry 0x400806b8
If the STA mode is used with an LTE router, it runs completely trouble-free. In AP mode and when Bluetooth and Wifi are active, resources are likely to be limited.
