“a device which doesn’t exist was specified”
I no longer have the full parameter list, f5 doesn’t reset list ,many uninstall and reinstalls ,reboots are no help. I made some changes to list before this problem. Is there a factory default reset??? The one on the config screen is not lit up. every thing worked before I made changes.
There is a parameter reset option in MP or another popular method is to temporarily load the firmware from another vehicle type (e.g. Copter or Plane) and then re-install Rover.
thanks for the awesome information.
Like I said in my comments, the parameter reset option is a lite green and is not working when pressed! I tried loading the firmware from another vehicle and loaded back to rover. It seems to work now!
Thank you for your help and dedication to the support group!
thanks my issue has been fixed.
