Edit: i just found a weird…tip. After putting in a graph xxx expression, i can make the graph appear very quickly by just typing in a few more graph (empty) expressions and somehow the graph just showed up. If I don’t do this it takes forever to load a graph. I’m not sure if this is a feature or a bug.
I’m new to Mavexplorer. Just downloaded the latest version and found the time to load any graph way too long to be useful. I have a log that is admittedly a bit on the large side at about 118Mb. Much of it is garbage data after the drone crashed. Just to plot a single parameter took minutes, while mission planner typically takes a split second. The reason I wanna use MavExplorer is to compare data of very different vertical scales. Any ideas?
