I have some trouble to get my Mauch current sensors working on an 18" X8 copter.
I have voltage info, but current data is a complete nonsense.
Hardware being used:
- Pixhawk 2.1 orange (copter 4.1 dev)
- 2x Mauch 003 PL-200 sensor
- Mauch 010 PL sensor hub x2
- Mauch 017 PL 4-6S BEC
- two 6S batteries
I followed the instructions provided by Mauch carefully and installed the hardware accordingly and double checked:
- current flow direction of sensors
- wiring from sensors to sensor hub
- wiring from hub to 017 BEC (BEC goes in Cube Power 1) Power 2 is powered by separate Mauch BEC.
I also triple checked all these infos from Mauch and ardupilot:
http://ardupilot.org/copter/docs/common-mauch-power-modules.html
Settings in MP:
Batt monitor 1: analog voltage and current
Sensor: other
HW Ver: 8: Cube orange (I tried “4: The Cube or Pixhawk” as well)
The calibrated values provided by Mauch (Voltage divider 19,00372 and A/V 121,24822) are simply calculated by these steps:
“You can calculate the total setting for Batt1 monitor in MissionPlanner:
Voltage divider = (Voltage divider sensor 1 + Voltage divider sensor 2) / 2
Amp/ Volt = Amp/V Sensor 1 + Amp/V Sensor 2”
When I enter these values, the calced voltage jumps to 62V (instead of 23,6V) and the amp draw to a VERY REALISTIC 250A when the copter is sitting on the workbench being disarmed. Current draw should be realisticly about 1A max at the moment.
When I enter the measured voltage as well, calced batt voltage turns out to be correct, but the divider drops to about 7 (which is not the value of the calibration sheet).
Calced current is still showing 250A with the factory A/V value from around 121.
Can someone find a solution?
Thanks a lot!
Geerd
