Hi
I started setting up MatekH743, connected to SpeedyBee ESC (BLS 50A 30x30), loaded with Bluejay firmware.
Matek FC is loaded with stable-bshot-4.4.4 firmware.
The only Dshot option that works is Dshot300, regardless SERVO_BLH_BDMASK ON/OFF on first 4 channels. ESC doesn’t complete the “ready” beeps and cannot spin the motors.
The interesting part is I can use Dshot600 with this ESC (and same bluejay firmware) using SpeedyBee FC with 4.4.3 firmware (Didn’t test 4.4.4 for this FC).
There’s some tests or setup options I could try to investigate this? I will just be happy using Dshot300 otherwise (if it’s reliable)
Thanks!
