Matek h743-slim: Freeze after boot / solid red LED
Hello
I have the problem that my FC freezes after boot and just shows solid RED LED.
It´s not possible to connect with GCS (USB and telemetry radio). Same problem when powering FC via USB.
I updated yesterday to Arducopter 4.0.7 and everything worked great - did also some test flight.
Today I did some tests with fport and telemetry script and also that worked. My only problem was that telemetry was not working when I put my frsky archer m+ output to "FBUS (F.PORT 2.0), but FPORT worked.
Suddenly the FC was not booting anymore. I checked SDCARD and downgraded back to 4.0.6, but still the same problem.
I can´t find any information about that problem and I also don´t understand the beep codes.
Here is a short video showing the boot sequenze.
Google Drive video link
Any idea whats wrong?
Thanks
Nicolas
This board has had some issues with flash corruption for which there are fixes in 4.0.7. What I suggest you try is wiping the flash by first loading 4.0.7 plane and then 4.0.7 copter again. You will need to reset your parameters afterwards.
Thanks!! That solved the problem!
So now I can continue to find out why FPORT 2.0 is not working.
No idea if that has any practical advantages, but I don´t understand why it is not working.
