I just loaded 4.09 on to a new Matek H743 Wing board. When I connect to it with Mission Planner at the end of the params loading I get an error ‘Missing Params 1195 vs 1194’.
I don’t know if it’s related but it’s also not displaying the current. I was calibrating the voltage/current reading and the current displayed just stays at whatever ‘measured current’ I enter in to the configuration. It doesn’t change as I vary the throttle. The voltage readout is working fine. I’ve set the voltage to pin 10 and current to pin 11 with no luck.
TIA
