I am using F765 FC
I have connected GPS to TX2, RX2 (Tx - Rx, RX - Tx) port wire connection is correct I have checked it properly. The soldering of wire and pins are also done properly. Battery 3s and USB connection for power.
(serial 3 = set to 5 ). GPS is new and working checked with other FC like ( APM 2.8)
Still, I am getting no GPS on MP. Though compass is working fine. GPS is showing a solid red LED.
pleas someone help.
Mine ist working fine with
SERIAL3_BAUD,38
SERIAL3_OPTIONS,0
SERIAL3_PROTOCOL,5
if you are sure that Rx/Tx is not accidentally plugged in the wrong way, I would connect the GPS to pin Tx3/Rx3 with
SERIAL4_BAUD,38
SERIAL4_OPTIONS,0
SERIAL4_PROTOCOL,5
to exclude a hardware failure on the Rx2/Tx2 Pins.
Rolf
finally, it is working now. I have done a full-chip clean and then install the new plane 4.0.9 firmware again on the FC.
Now It is working fine but I am getting ( GPS = no fix ) issue what should I do about that.
i have same issue on omnibus nano v6. i tried everything, from swapping cables to changing ports, to trying various params (options etc) nothing worked. If i flash INAV, i can get it working thoug… however not with arduplane. PS mine is a M8N
