Hello. I’m running into issues while trying to calibrate my Matek F405 VTOL flight controller. Does anyone know of a work around for the following error…?
3/22/2023 1:45:27 AM : Config Error: fix problem then reboot
3/22/2023 1:45:25 AM : Config Error: INS: unable to initialise driver
Initially I was running into problems trying to do the initial sensor calibration so I wiped the board and loaded it with the latest arduplane_with_bl.hex file and now I’m getting this error when I connect via mission planner.
Any ideas?
But now I’m back to the problem of not being able to calibrate the sensors. When I lay it level to do the initial calibration I get “The Command failed to execute” Error.
I read somewhere that it may be exceeding its max pitch angle and that’s why I’m getting the error?
Once you have ArduPlane on the board you can update or change versions without needing DFU. The trick is plug the board into your computer, but don’t press the “connect” button in mission planner. Just go directly to the firware update section in mission planner.
If you already have an Ardupilot firmware on the board you shouldn’t need DFU. But you can force the board into DFU mode by pressing the little button on the break out board beside USB port when you plug in the board.
BTW, I really appreciate all the help guys. This is for a project for my degree and it’s had me pretty stressed. Getting this much help is really refreshing.
Nope. It asks me “Do you want to upload this via DFU?”, then I hit cancel and the following message pops up…“Cant detect your Board version. Please check your cabling”.
So after stepping away for a few hours and then approaching it with a rested mind I was able to resolve the issue. I was so frustrated with it before that I’m sure I was missing some steps. I think stepping away when frustrated should be an unofficial rule for all things ardupilot :). Thanks again guys!
