I am unable to get GPS fix in the Holybro M9N and F405-miniTE setup. attached the parameter file
f405miniTE.param (18.6 KB)
swapped RX TX PIN. - NO USE - when Swapped it dindn’t even showed GP1 detected
Connected to tx5 and rx5 PIN - Serial 3.
3.Changed BAUD rate to 230, but no use.
any help
Allister
(Allister Schreiber)
February 18, 2024, 1:12am
2
No Fix means the GPS is detected and working. It just hasn’t got enough position information yet. Are you inside or out? Does the GPS have a clear view of the sky?
i am outside, and clear to sky
Yuri_Rage
(Yuri Rage)
February 18, 2024, 1:52am
4
Is there an antenna connected?
other than GPS antenna?
no only M9N unit is connected to flight contoller
Yuri_Rage
(Yuri Rage)
February 18, 2024, 1:59am
6
Indeed. I’m asking if there is a GPS antenna either built in or connected. What you are showing is a valid configuration with no reception.
Let it sit for 15 minutes, powered on and see if anything changes.
Okay, yes GPS antenna built in!
Guys, Problem solved. looks like a faulty GPS unit. soldered a new M9N holybro GPS and it worked like a charm.
Thanks for the help guys.
