Matek F405 mini TE optical flow missing parameters
Hi everyone.
We are making a small indoor 4" drone with the board, Matek F405 Mini TE and ardupilot, to can use optical flow and rangefinders
Previously, we have tested this hardware with another old board, the matek f405 STD without any problems, all systems ok, rangefinders and optical flow.
WIth the new board, the f405 mini te, in the arducopter firmware 4.2.0, there are missing the parameters of the optical flow setup.
the flow_type is missing, therefore we dont use optical flow
anyone knows why?
even we have build a custom firmware with the optical flow parameters included, but not works too.
any solution??
@PVR2022,
It looks like that particular board is so low on flash that optical flow support has been removed (see this pull requrest. I think these low end boards are so extremely low on flash space very difficult choices need to be made. I think if the AP_OPTICALFLOW_ENABLE definition is set to 1 then it should work. It might help to use the custom build server.
FYI @peterbarker.
Custombuilder works for me on a Speedbee F405 WING and the Matek OPTICAL FLOW 3901-L0X with the following extra’s enabled:
Sensors
  • Optical Flow
  • Optical flow CXOF Sensor
  • Optical flow MAVLink Sensor
  • Optical flow ONBOARD Sensor
  • Optical flow PIXART Sensor
  • Optical flow PX4FLOW Sensor
  • Optical flow UPFLOW Sensor
MSP
  • MSP OpticalFlow
  • MSP Sensors
I’m not 100% sure you need all the optical flow sensors, but this works for me.
matek service make an special custom firmware for us with the features we need.
thanks a lot to matek service
Hello, I have the same problem. I need the modified firmware. How can I find it for matek f405-te?
Try the Custom Build Server.
