- That is a
.param
file, not a.bin
log file - Did compass detection ever work? That is not clear to me yet.
- That might have been on the edge. So testing it makes sense.
- OK
- OK
- OK
- You should have started a new thread, like we asked you to. This is a 4.0 thread.
- log - Google Drive
this is the .bin file - yes it worked earlier with same parameter file that i have already shared in this thread.
- sorry, I didn’t do new thread on this. because this was issue already faced by the this thread owner(sep 2020) and i continued later in this year asking weather had a solution for the issue.
It might have worked on the edge. It is worth to test again.
tested it, unfortunately not working.
It’s not showing a barometer. Try re-flashing the firmware.
re-flashed and no baro showing in HW ID
To be sure you have the right firmware download the .apj file from here and use the “load custum firmware” in Mission Planner.
firmware
Other than that perhaps the board is bad.
Okay maybe broad would be the culprit
Yes, Guys. this board was culprit. Luckily I had a f405-ctr in my stock and checked with that one and it’s working.
Thanks a bunch guys.
