MATEK F-765-WING with sensors MATEK
Checking the health of the flight controller MATEK F-765-WING with sensors MATEK GPS&Compass M8Q-5883, MATEK Analog Airspeed Sensor ASPD-7002, MATEK Lost Model Beeper SKU: DBuz5v. https://youtu.be/P6vDcpMvtCs
The main parameters for installing the controller configuration:
UART 7_Telemetry 1_SERIAL1_BAUD,57 OPTIONS,0 PROTOCOL,1
UART1
Telemetry 2
SERIAL2_BAUD,57_OPTIONS,0_PROTOCOL,-1
USART2_GPS1_ SERIAL3_BAUD,38_OPTIONS,0_PROTOCOL,5
USART3_GPS2_ SERIAL4_BAUD,38_OPTIONS,0_PROTOCOL,-1
Rx6_SBUS (FrSky L9R)
BATT_AMP_PERVOLT,40
BATT_CARR_PIN,13
BATT_MONITOR,4
BATT_VOLT_MULT,11
BATT_VOLT_PIN,12
RSSI_ANA_PIN.11
RSSI_PIN_HIGH,3.2
ARSPD_PIN,10
ARSPD_TUBE_ORDER,0
ARSPD_TYPE,2
TERRAIN_ENABLE,0
OSD_TYPE,1
The result of the test: the necessary functions for the aircraft work correctly, the MATEK F-765-WING controller is correct and can be installed on the aircraft.
