Hi Everyone. I have downloaded the latest version of Mission Planner and when installed on Computer. I am unable to find the maps as it displays some error.
Can Anyone look into this and give me the solution.
I have changed the maps to different formats but still, the same problem exists.
I am from India, is this the location issue?
Thanks in advance
The red text says the error, your internet connection is behind a proxy which needs authentication.
Mission planner not capable to handle such proxy connections. you need a direct internet connection (or behind a simple NAT) to use it.
Thank You so much for your suggestion.
I have tried even that, installing MP with mobile internet but the problem still exists?
disable your proxy settings inside edge/internet explorer.
