I encounter a difficulty when I want to arm my Pixhawk after all calibration. I can’t arm with my transmitter. The left stick control Throttle and Yaw, and the right stick control Pitch and Roll. So I try to hold the right stick (steering stick I supposed) on the right but nothing happen.
When I press the arming button on my ground station, my pixhawk is armed (fix blue light) but it still appear DISARMED on GCS.
Someone can please help me ?
I try to fix this problem since 3 days. When I load ArduPlane firmware V3.6.0 on my Pixhawk I can arm without any problem (left stick hold in the bottom right-hand corner, throtlle and yaw at minimum).
I suppose it’s a firmware problem or configuration problem ?
I think there was a bug in 3.0. Try changing the ARMING REQUIRED parameter so you do not need to arm. Or, I think there is a Beta Rover 3.0.1 with the arming bug fixed.
Thank you for helping.
Now I would like to configure my motors in this way :
When I hold the steering stick on the right, 1 motor turn in one direction and the other motor turn in the opposite direction (so the boat turn on the right). Is it possible to do something like that ?
Yes, it is possible. You would use the SKID STEERING parameters. I have never used them so I can’t give any reliable advice. Its in the Wiki and others have used it successfully. Glad I could help a bit.
Thanks for helping out David - its really appreciated.
Edouard - Skid steering doco is here: http://ardupilot.org/rover/docs/skid-steer-parameter-tuning.html
Remember to set ONLY 1 of the parameters - never both.
And you probably want SKID_STEER_OUT=1 based on the transmitter you have.
I’ll be releasing the new stable version of Rover shortly with the fixes in it.
Thanks, Grant.
