Why would so many [important] params not load from a file that was successfully saved? I can’t post a screen shot, but it says there are 57 missing params, including Battery, PIDs, Serial, OSD, and VTX. That’s pretty much everything that matters and was configured over the course of weeks. Furthermore, I had tried loading saved settings because most of my settings were just randomly gone.
Without a screenshot we can not help you. And please post at least your parameter file
you need to restore the parameters then reboot and restore again, some parameters wont appear until initial parameters have been set so you have to restore then reboot a couple of times to get them all.
That did it. Thank you so much! After months of patiently (and frustratingly) learning Ardupilot I was about to give up after this happened; unfortunately speaks to the bane of using Ardupilot. I really do appreciate your knowledge and help, especially considering in the short time I’ve been using the discussion board and the one too many unhelpful, snarky people I’ve encountered.
