hello everyone,
I just flash ardupilot to the board, when I try to setup the flysky fs ia6b I can get any of my uart any idea how can I fix this.
hi dalkon,
I don’t know how to fix this, but as a workaround you can try changing the SERIAL parameters in CONFIG, Full Parameter List
okey thank you. I will do that
Try updating Mission Planner. There is a newer release. I don’t know if that will fix the page you are viewing, but it can’t hurt to be up to date on the software.
This does appear to be a problem with Mission Planner and not necessarily your hardware. @Eosbandi may have some insight.
maybe I miss some parts while downloading ardupilot
No. I think you just need to update Mission Planner as a first step.
thank you I will try it, but when I connect with other board it works?
