I build a docker machine as stated on Ardupilot website.
I try now to compile for obal board to be used with Pi 4.
I receive this error :
make obal
Setting top to : /ardupilot
Setting out to : /ardupilot/build
Autoconfiguration : enabled
Checking for program 'python' : /usr/bin/python
Checking for python version >= 3.6.9 : 3.10.12
Setting board to : obal
Using toolchain : arm-linux-gnueabihf
Checking for 'g++' (C++ compiler) : /usr/lib/ccache/arm-linux-gnueabihf-g++
Checking for 'gcc' (C compiler) : /usr/lib/ccache/arm-linux-gnueabihf-gcc
Checking for c flags '-MMD' : yes
Checking for cxx flags '-MMD' : yes
CXX Compiler : g++ 11.4.0
Checking for need to link with librt : not necessary
Checking for 'lttng-ust': : disabled
Checking for library dl : yes
Checking for program 'arm-linux-gnueabihf-pkg-config' : /usr/bin/arm-linux-gnueabihf-pkg-config
Checking for 'libiio' : not found
Enabled OpenDroneID : no
Enabled firmware ID checking : no
GPS Debug Logging : no
Enabled custom controller : no
Checking for HAVE_CMATH_ISFINITE : yes
Checking for HAVE_CMATH_ISINF : yes
Checking for HAVE_CMATH_ISNAN : yes
Checking for NEED_CMATH_ISFINITE_STD_NAMESPACE : yes
Checking for NEED_CMATH_ISINF_STD_NAMESPACE : yes
Checking for NEED_CMATH_ISNAN_STD_NAMESPACE : yes
Checking for header endian.h : yes
Checking for header byteswap.h : yes
Checking for HAVE_MEMRCHR : yes
Traceback (most recent call last):
File "/ardupilot/modules/waf/waflib/Scripting.py", line 158, in waf_entry_point
run_commands()
File "/ardupilot/modules/waf/waflib/Scripting.py", line 251, in run_commands
ctx = run_command(cmd_name)
File "/ardupilot/modules/waf/waflib/Scripting.py", line 235, in run_command
ctx.execute()
File "/ardupilot/modules/waf/waflib/Configure.py", line 159, in execute
super(ConfigurationContext, self).execute()
File "/ardupilot/modules/waf/waflib/Context.py", line 204, in execute
self.recurse([os.path.dirname(g_module.root_path)])
File "/ardupilot/modules/waf/waflib/Context.py", line 286, in recurse
user_function(self)
File "/ardupilot/wscript", line 496, in configure
cfg.get_board().configure(cfg)
File "/ardupilot/Tools/ardupilotwaf/boards.py", line 175, in configure
c_cpp_properties = json.load(open(os.path.join(env.SRCROOT, '.vscode/c_cpp_properties.json')))
File "/usr/lib/python3.10/json/__init__.py", line 293, in load
return loads(fp.read(),
File "/usr/lib/python3.10/json/__init__.py", line 346, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.10/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.10/json/decoder.py", line 353, in raw_decode
obj, end = self.scan_once(s, idx)
json.decoder.JSONDecodeError: Expecting property name enclosed in double quotes: line 8 column 13 (char 159)
