‘qtmake-qt4 qgroundcontrol.pro’ does not work, so I run
’qmake qgroundcontrol.pro’
and get the following error:
cj@x201i ~/workspace/apm_planner $ qmake qgroundcontrol.pro
Project MESSAGE: Qt version 5.0.1
Project MESSAGE: Linux build
Project MESSAGE: Release flavor
Project MESSAGE: BASEDIR /home/cj/workspace/apm_planner DESTDIR /home/cj/workspace/apm_planner/release TARGET apmplanner2
/home/cj/workspace/apm_planner/QGCExternalLibs.pri:379: Extra characters after test expression.
Project ERROR: Unknown module(s) in QT: script declarative webkit phonon svg
and now I’m stuck and was wandering if anyone can offer advice.
Regards
Chris
PS - very much a Linux noob, so if you can help please spell it out for me, thanks
so close now… OK, so now onto the next problem
Running the command:
The spash screen opens and then the gui errors:
I don’t see a directory ‘qml’ under home/cj/
The terminal output:
[quote]cj@x201i ~ $ ./workspace/apm_planner/release/apmplanner2
QsLog: could not open log file /home/cj/apmplanner2/log.txt INFO 2014-03-28T09:36:40.782 QGCCore::initialize()
INFO 2014-03-28T09:36:40.783 Current Build Info
INFO 2014-03-28T09:36:40.783 Git Hash: d28be19ddf037bff3bb5bc34f2c7c10ad47498b7
INFO 2014-03-28T09:36:40.783 Git Commit: 2.0.7-27-gd28be19
INFO 2014-03-28T09:36:40.783 APPLICATION_NAME: "APM Planner"
INFO 2014-03-28T09:36:40.784 APPLICATION_VERSION: "v2.0.7"
INFO 2014-03-28T09:36:40.876 Start Link Manager
INFO 2014-03-28T09:36:40.894 Start UAS Manager
INFO 2014-03-28T09:36:40.901 UDP Created "UDP Link (port:14550)"
DEBUG 2014-03-28T09:36:40.902 Creating MainWindow
INFO 2014-03-28T09:36:41.157 Creating SubMainWindow: SubMainWindow(0xadc27d8)
INFO 2014-03-28T09:36:41.157 setting objectName: "VIEW_MISSION"
INFO 2014-03-28T09:36:41.263 Creating SubMainWindow: SubMainWindow(0xae26180)
INFO 2014-03-28T09:36:41.263 setting objectName: "VIEW_FLIGHT"
INFO 2014-03-28T09:36:41.337 Creating SubMainWindow: SubMainWindow(0xae50be8)
INFO 2014-03-28T09:36:41.337 setting objectName: "VIEW_HARDWARE_CONFIG"
DEBUG 2014-03-28T09:36:41.624 fillPortsInfo
INFO 2014-03-28T09:36:41.635 Inserting "ttyUSB0"
INFO 2014-03-28T09:36:41.635 Changed Link to: "ttyUSB0"
INFO 2014-03-28T09:36:42.144 Creating SubMainWindow: SubMainWindow(0xadd54b8)
INFO 2014-03-28T09:36:42.144 setting objectName: "VIEW_SOFTWARE_CONFIG"
DEBUG 2014-03-28T09:36:42.175 Disable Controls
INFO 2014-03-28T09:36:42.651 Creating SubMainWindow: SubMainWindow(0xb55a480)
INFO 2014-03-28T09:36:42.651 setting objectName: "VIEW_ENGINEER"
INFO 2014-03-28T09:36:42.699 Creating SubMainWindow: SubMainWindow(0xb59c4a0)
INFO 2014-03-28T09:36:42.699 setting objectName: "VIEW_MAVLINK"
INFO 2014-03-28T09:36:42.732 Creating SubMainWindow: SubMainWindow(0xb5aaa98)
INFO 2014-03-28T09:36:42.732 setting objectName: "VIEW_SIMULATOR"
INFO 2014-03-28T09:36:42.807 Creating SubMainWindow: SubMainWindow(0xb5ee9c8)
INFO 2014-03-28T09:36:42.807 setting objectName: "VIEW_TERMINAL"
DEBUG 2014-03-28T09:36:42.822 fillPortsInfo
INFO 2014-03-28T09:36:42.834 Inserting "ttyUSB0"
INFO 2014-03-28T09:36:42.834 Changed Link to: "ttyUSB0"
DEBUG 2014-03-28T09:36:42.915 MODE: 0
DEBUG 2014-03-28T09:36:42.917 "D|PREFLIGHT"
DEBUG 2014-03-28T09:36:42.917 MODE: 80
DEBUG 2014-03-28T09:36:42.918 "D|STABILIZED"
DEBUG 2014-03-28T09:36:42.918 MODE: 64
DEBUG 2014-03-28T09:36:42.919 "D|MANUAL"
DEBUG 2014-03-28T09:36:42.919 MODE: 88
DEBUG 2014-03-28T09:36:42.920 "D|VECTOR|STABILIZED"
DEBUG 2014-03-28T09:36:42.921 MODE: 92
DEBUG 2014-03-28T09:36:42.921 "D|AUTO|STABILIZED"
DEBUG 2014-03-28T09:36:42.922 MODE: 66
DEBUG 2014-03-28T09:36:42.922 "D|TEST"
INFO 2014-03-28T09:36:43.117 UASActionsWidget creating UASActionsWidget(0xb6e9e48)
INFO 2014-03-28T09:36:43.371 Using Alsa Audio driver
WARN 2014-03-28T09:36:43.372 Dir directory tmp_audio exists
DEBUG 2014-03-28T09:36:43.384 qmlBaseDir "/home/cj"
DEBUG 2014-03-28T09:36:43.386 QUrl( “file:///home/cj/qml/ApmToolBar.qml” )
QFont::setPointSizeF: Point size <= 0 (-0.950000), must be greater than 0
QFont::setPointSizeF: Point size <= 0 (-0.950000), must be greater than 0[/quote]
[quote=“cjyoyogi”]
PS - I think it would be really helpful to link to the binaries from the download page, only Windows and Mac are shown[/quote]
They where first posted yesterday. A link to the first stable release will be posted to the downloads section in the next couple of days.
