I got the following Error:
Could anyone help please?
[code]HFAI@PC ~/ardupilot/ArduCopter
$ git clone git://github.com/diydrones/ardupilot.git
Cloning into ‘ardupilot’…
remote: Counting objects: 144648, done.
remote: Compressing objects: 100% (59/59), done.
remote: Total 144648 (delta 29), reused 0 (delta 0), pack-reused 144589
Receiving objects: 100% (144648/144648), 74.98 MiB | 99.00 KiB/s, done.
Resolving deltas: 100% (103620/103620), done.
Checking connectivity… done.
Checking out files: 100% (2253/2253), done.
$ make sitl -j4
echo "Generating MAVLink headers…"
Checking modules
#goto mavlink module directory and run the most recent generator script
echo “Generating C code using mavgen.py located at” /home/HFAI/ardupilot/modules/mavlink/
Generating C code using mavgen.py located at /home/HFAI/ardupilot/modules/mavlink/
PYTHONPATH=/home/HFAI/ardupilot/modules/mavlink/ python /home/HFAI/ardupilot/modules/mavlink//pymavlink/tools/mavgen.py --lang=C --wire-protocol=1.0 - -output=/tmp/ArduCopter.build/libraries/GCS_MAVLink/include/mavlink/v1.0 /home/HFAI/ardupilot/modules/mavlink//message_definitions/v1.0/ardupilotmega. xml
// BUILDROOT=/tmp/ArduCopter.build HAL_BOARD=HAL_BOARD_SITL HAL_BOARD_SUBTYPE=HAL_BOARD_SUBTYPE_NONE TOOLCHAIN=NATIVE EXTRAFLAGS=-DGIT_VERSION="e78595 bf"
Validating /home/HFAI/ardupilot/modules/mavlink//message_definitions/v1.0/ardupilotmega.xml
Parsing /home/HFAI/ardupilot/modules/mavlink//message_definitions/v1.0/ardupilotmega.xml
Note: message DATA64 is longer than 64 bytes long (74 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transf er unit.
Note: message DATA96 is longer than 64 bytes long (106 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air trans fer unit.
Note: message REMOTE_LOG_DATA_BLOCK is longer than 64 bytes long (214 bytes), which can cause fragmentation since many radio modems use 64 bytes as ma ximum air transfer unit.
Validating /home/HFAI/ardupilot/modules/mavlink//message_definitions/v1.0/common.xml
Parsing /home/HFAI/ardupilot/modules/mavlink//message_definitions/v1.0/common.xml
Note: message GPS_STATUS is longer than 64 bytes long (109 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air t ransfer unit.
Note: message ATTITUDE_QUATERNION_COV is longer than 64 bytes long (76 bytes), which can cause fragmentation since many radio modems use 64 bytes as m aximum air transfer unit.
Note: message GLOBAL_POSITION_INT_COV is longer than 64 bytes long (193 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit.
Note: message LOCAL_POSITION_NED_COV is longer than 64 bytes long (237 bytes), which can cause fragmentation since many radio modems use 64 bytes as m aximum air transfer unit.
Note: message HIGHRES_IMU is longer than 64 bytes long (70 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air t ransfer unit.
Note: message HIL_SENSOR is longer than 64 bytes long (72 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air tr ansfer unit.
Note: message SIM_STATE is longer than 64 bytes long (92 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air tra nsfer unit.
Note: message FILE_TRANSFER_PROTOCOL is longer than 64 bytes long (262 bytes), which can cause fragmentation since many radio modems use 64 bytes as m aximum air transfer unit.
Note: message HIL_STATE_QUATERNION is longer than 64 bytes long (72 bytes), which can cause fragmentation since many radio modems use 64 bytes as maxi mum air transfer unit.
Note: message LOG_DATA is longer than 64 bytes long (105 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air tra nsfer unit.
Note: message GPS_INJECT_DATA is longer than 64 bytes long (121 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit.
Note: message SERIAL_CONTROL is longer than 64 bytes long (87 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum ai r transfer unit.
Note: message ENCAPSULATED_DATA is longer than 64 bytes long (263 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximu m air transfer unit.
Note: message RESOURCE_REQUEST is longer than 64 bytes long (251 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit.
Note: message CONTROL_SYSTEM_STATE is longer than 64 bytes long (108 bytes), which can cause fragmentation since many radio modems use 64 bytes as max imum air transfer unit.
Note: message AUTOPILOT_VERSION is longer than 64 bytes long (68 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit.
Note: message V2_EXTENSION is longer than 64 bytes long (262 bytes), which can cause fragmentation since many radio modems use 64 bytes as maximum air transfer unit.
Merged enum MAV_CMD
Found 176 MAVLink message types in 2 XML files
Generating C implementation in directory /tmp/ArduCopter.build/libraries/GCS_MAVLink/include/mavlink/v1.0/ardupilotmega
Generating C implementation in directory /tmp/ArduCopter.build/libraries/GCS_MAVLink/include/mavlink/v1.0/common
Copying fixed headers
D:/SOS/ArduPilot/Cygwin/home/HFAI/ardupilot/mk/mavgen.mk:9: recipe for target ‘/tmp/ArduCopter.build/libraries/GCS_MAVLink/include/mavlink/v1.0/ardupi lotmega/mavlink.h’ failed
make: *** [/tmp/ArduCopter.build/libraries/GCS_MAVLink/include/mavlink/v1.0/ardupilotmega/mavlink.h] Aborted (core dumped)
make: *** Deleting file ‘/tmp/ArduCopter.build/libraries/GCS_MAVLink/include/mavlink/v1.0/ardupilotmega/mavlink.h’
[/code]
