Just got my self an AMP 2.6 (been flying on CC3D for a while now) and I am having issues getting the APM to recognize the 3DR radio thats plugged into the USB.
Running Mac OS X Yosemite version 10,10
See the first screenshot, its my System Information screen. The APM 2.6 plugged into one USB port is recognized as the Arduino Mega 2560, and I can connect to the board no prob through APM Planner
When I plug in the 3DR radio into the USB it comes up as the “CP2102 USB to UART Bridge Controller”. Is this the correct for the device?
Second screenshot, when I try to connect to the APM through the Initial Setup/3DR Radio screen, the Link Settings Dropdown is blank, and there are no values in it.
If I go to the Advanced Settings screen, I get the following list of devices that APM Planner sees. In there I see the usbmodem1411 which is the USB to the APM 2.6, and then I see all my bluetooth modules (BATTY, CRASHBOT). But I do not see the 3DR radio.
Am I doing something wrong here? Am I going to the right screens to setup the 3DR radio?
Where did you get your radio? The 3DR Radio uses a FTDI chip. I have found you need to install the FTDI drivers for them to work (the one built into OSX does not). The tested one is in the downloaded .dmg
I got the 3DR radio from Multirotomania, a legit store in CA. My driver I got from here: ftdichip.com/Drivers/VCP.htm
IN the screenshot attached you can see that with the drive installed when I plug in the radio it shows up as “CP2102 USB to UART Bridge Controller” in Mac’s System Information.
Humm, from reading the FTDI site I can see that I am supposed to see the device pop up as
My only guess is that you are not using a 3DR Radio that is using the FTDI chip, but some variant with a new USB chip from SiLabs. Try installing the driver for that. (it not a genuine ‘3dr Radio’ meaning it’s a hardware derivative, so needs different drivers)
If it’s installed correctly, you should see the device listed by going to terminal and typing ls /dev/cu.*
If it does not appear contact the manufacturer on how to install the radio to work on OSX. I don’t have one to test. Send me one I can probably figure it out.
