I’m trying to stop the motor when RPM threshold reached, using Lua script. Now I’m able to read the RPM value in QUICK, meaning the sensor works fine. But when I run the script it shows " RPM value not available" as per script, in the messages. Could you guide me with what I have missed ?
The RPM sensor is connected to AUX PWM pin1 (GPIO) and powered by ESC BEC connected to PWM AUX pin2 , SERVO10_FUNCTION = motor1.
SCR_ENABLE is enabled.
local motor_channel = 10 -- Channel for the motor
local rpm_threshold = 100 -- RPM threshold for disengagement
function update()
local rpm_value = RPM:get_rpm(1) -- Read the RPM value from instance 1
if rpm_value then
gcs:send_text(6, "RPM Value: " .. tostring(rpm_value))
if rpm_value >= rpm_threshold then
gcs:send_text(6, "RPM threshold reached, disengaging motor")
SRV_Channels:set_output_pwm_chan_timeout(motor_channel, 1000, 1000) -- Stop the motor
end
else
gcs:send_text(6, "RPM Value not available")
end
return update, 1000 -- Schedule the update function to run again in 1000 milliseconds
end
return update, 1000 -- Schedule the update function to run for the first time in 1000 milliseconds
Thanks
