It constantly tells me the voltage is low. It isn’t. And I can’t seem to figure out how to tell it the correct voyage to warn me and or don’t tell me at all. Which setting please?? Thx
You should be able to go into initial settings screen and go to fail safe, then use the drop down menu to select the correct voltage you are looking for. Make sure you are using a power module so it can monitor the battery voltage. You set that up in the Optional Hardware section. Then go to Battery monitor I believe it is called.
Thanks!
