Hi all,
I’ve found some low cost all in one F7 based controller on aliexpress;
are they supported ?
example
i’m searching for a compact solution to build a 330 hobby drone able to support autonomous flight for my knowledge and test.
Thanks
Hi all,
example
Thanks
From what I could understand, it does not appear to have 1MB flash, which is essential for ardupilot.
On the link below you can find all the FC-s supported by ardupilot.
https://ardupilot.org/copter/docs/common-autopilots.html
I suggest you go with one of the Matek boards, I think they are the cheapest.
Thank you very much for your kind answer.
I’ll follow your hint.
f
Right, 3 things to consider:
Minimum 1MB Flash
Barometer
A firmware version for it (unless you are compiling one)
