Thanks for putting that in there Michael .
It would be really cool if the survey grid could be nudged (shifted) with the arrow keys (or another means) to center it more precisely in the area.
After playing around a bit, I found that changing the sidelap affects the position of the grid in the poly. I was able to increase the overlap to center the grid without adding additional lines.
How do you setup such a survey?
In the Flight Plan screen right click on the map and choose Draw Polygon>Add Polygon Point to start drawing a polygon on the screen. When you finish drawing your polygon right click on the screen and choose Auto WP>Survey (Grid). This will bring up the dialog you see in my previous post. You can choose your camera, altitude, speed, overlap, etc. It will automatically calculate and create the mission based on your settings.
It doesnβt get much cooler than that.
