stefymtb
(step)
December 3, 2024, 6:09pm
1
Could you please help me?
Model is AR wing PRO, i fly it without problem…untill today.
On the third part of the flight, the plane was loitering.
It started drifiting down and left and reached around 150-180 km/h.
I switched to manual mode and slowly decelerated. But the plane was responding wrong.
Rolling produced an erratic movement and pitch also.
I was able to slowly come down and landed as i could in a near field (No damages, but i was lucky!)
What happened?
I had a look at the log, i can see something is wrong. But i am not so into it to understand what.
Here is the log: Unique Download Link | WeTransfer
stefymtb
(step)
December 3, 2024, 6:11pm
2
Additional information: i thought i lost use of an elevon.
They seems good after inspection, and servos working well even under load.
I can not understand why i was not able to pilot even in manual mode.
Video footage of erratic loitering: https://youtu.be/cMKFCUS6VAI
Allister
(Allister Schreiber)
December 4, 2024, 1:19am
3
The log file is not available.
stefymtb
(step)
December 4, 2024, 7:07am
4
Log erratic flight
Flight log from previous flight
kd0aij
(Mark Whitehorn)
December 4, 2024, 2:38pm
5
Servo channel 2 pegs at 1100 before things go wrong in loiter.
So I’d say you lost your right elevon.
stefymtb
(step)
December 4, 2024, 6:22pm
6
I will check again, to me it works. But of course…not.
Thank you mate!
kd0aij
(Mark Whitehorn)
December 4, 2024, 6:41pm
7
Check for an intermittent problem; maybe a loose servo connection, or flaky servo.
I’ve seen a similar problem with damaged servo gears too (broken teeth can result in somewhat random behavior).
stefymtb
(step)
December 4, 2024, 8:08pm
8
Thank you Mark!
I am suspicious about wing connection connector.
When wing is under load, they may detach.
I have seen this in slope gliders using the green multiplex wing connectors.
