Looking for suggestions to protect 4-in-1 ESC in addition to Conformal and/or Kapton tape
I’m working on a team that has selected these 20x20 FETTec 4-in-1 ESCs for a “mini” quad build.
Unlike other 4-in-1 ESCs I’ve used, there are no heat sinks that protect the electronics. And the electronics need protecting. (Ask me how I know…)
We’re looking for suggestions on providing insulating protection to these devices - in order to make sure we’ve considered all the best options.
Our first thoughts were a couple of heavy coats of Conformal. And then maybe some Kapton tape.
These things get fairly warm.
We’d appreciate suggestions on other techniques we might consider trying.
Many Thanks!
That looks similar to many 4-in-1 ESC’s. What’s the problem mounting with standard stand-offs? Protecting from what?
I agree - it does seem a lot like other bits of electronics. Which is probably why we didn’t take any particular precautions.
Our mounting for this ESC is isolated and secure - no problem there. But we’ve managed to toast three of these in general installation handling.
Obviously, just taking greater care will help - especially if these things are particularly vulnerable to things like static discharge.
I just thought it would be worth asking for suggestions - in case there were techniques we were unfamiliar with so far.
Thanks!
Avoid conformal coatings and direct contact with that board, since it likely relies on air movement to dissipate heat. You could use a stacked standoff arrangement and fashion a plastic shield that sits slightly above it if you are concerned about fat fingers and errant conductors.
Thanks Yuri -
Yes - heat dissipation is something to think about.
I did a quick bit of research - and found this:
The conformal I have on hand is silicone based.
The quads we’re building are light-duty, short flight oriented - for STEM schools.
An alternate might be to use some kapton tape. I think we’re going to have to do a bit of experimentation.
