Long range video transmission via jetson
I have my CSI camera connected to the jetson nano, and i am running some object detection algorithms in jetson nano. I want to forward the live video stream with the detected bounding box results images to the ground station which is 5km away from the UAV. I cannot use internet . Any RF transmitters that you can suggest for long range video transmission processed from jetson nano. I have seen FPV camera with transmitters, but those transmitters transmit the live video feed from drone, but i need to send processed video from jetson nano to the transmitter and transmitter should send to ground station.There should be some connection with jetson nano to transmitter which i am missing. Any suggestions in this greatly appreciated.
Thank you in advance.
Hello, I have the same problem. Did you solve it?
